Warn winch xd9000
Submitted: Saturday, Jun 06, 2009 at 18:02
ThreadID: 69568 Views:2257 Replies:2 FollowUps:1
Any advice regarding a lever problem with a warn winch. Electric motor working fine via controller. No forwards or backwards though. Lever arm wont budge to freespool winch. Just been stripped and regreased. All relays just replaced. Thanks.
Reply By: Member - Stuart P (WA) - Saturday, Jun 06, 2009 at 18:51
the free spool lever slides in and out and can be put in back to front
AnswerID: 368740
Reply By: blue one - Saturday, Jun 06, 2009 at 19:51
Pull the end housing off and take out the slipper gear. Reverse the slipper gear and replace.
Did it myself before.
AnswerID: 368745
Follow Up By: Member - Adam S (SA) - Sunday, Jun 07, 2009 at 16:59
As blue one said, the most external gear (one that slips into end case) has a slot that runs around the outside.
That slot has to match the hole where the clutch lever is.
This is as clear as mud, Just do what blue one said take out the most external gear and put it in the other way.
Good luck.
FollowupID: 636341
