Sr brakes different to sr5?? Want to change rims and tyres.
Submitted: Tuesday, Jun 16, 2009 at 18:35
Name Not Found
Thanks to all out there for some helpful info replied to my last thread - I have now bought a 4x4 hilux SR dual cab tray....I am wanting to fit current SR5 rims and tyres but have heard they wont fit because the SR has larger brakes??? ....Can anyone confirm different brake sizes or will current SR5 alloys bolt straight on to my SR? (and yes I am getting flares if
wheels can be changed).....also... will my SR wheel nuts suit?
Thanks to all, Dave.
Reply By: Member - Andrew L (QLD) - Tuesday, Jun 16, 2009 at 19:03
I doubt that there would be different front brake disc rotor and rear bake drum diametres between the Hilux SR and SR5's. They are the same vehicle except for trim and bling level, they run the same engines, transmission, and rear cart springs etc, so load ratings would be the same or similar.
As to the different wheel studs, the steel SR
wheels would be a tapered
seat nut and the usual Toyota 12mm x 1.5 mm pitch, however the alloy SR5
wheels may have a shank nut, best use the same nuts for the same
wheels, but also make sure they have the same wheel stud length between the SR and SR5.
370376
Follow Up By:- Tuesday, Jun 16, 2009 at 19:26
thanks Andrew L, all info is appreciated...dave. What about brake callipers...sr5 has a.b.s. and sr doesn't is one set larger than other???
637697
Reply By: Batman69 - Tuesday, Jun 16, 2009 at 19:50
Dave,
For all info on Hilux's check out www.newhilux.net.
The brakes and calipers will not effect the fitting of SR5 alloys. They will bolt straight on, but you will need wheel nuts to suit the alloys.
There is plenty of stuff on the Newhilux website that you will find invaluable.
Steve.
370390
Follow Up By:- Tuesday, Jun 16, 2009 at 20:58
cheers batman69....I'll check it out tonight.
637720
Reply By: olcoolone - Tuesday, Jun 16, 2009 at 20:26
Brakes and
suspension are the same on all of the Hilux 4x4's
The
wheels are interchangable.
The steel wheel nuts will not suit alloy
wheels, if you are buying a set of alloys they should have the wheel nuts with them.
Not sure if the alloy rims will sit inside the front gaurds, you may have to fit flares.
370409
