Compare up to 4 tyre sizes at one time - Calculator
Submitted: Wednesday, Jun 17, 2009 at 16:21
ThreadID: 69916 Views:3764 Replies:4 FollowUps:8
To those that can access it - I have placed a calculator for tyre sizes in members file swap that will allow you to enter 4 different sizes and compare against your standard tyre size (Put it together when I was looking for tyres as it was hard to compare multiple tyres). Link Below & look for file
Compare Various Tyre Sizes - Quick Calculator
Hope it helps Cheers Tony
Reply By: Member - Graham H (QLD) - Wednesday, Jun 17, 2009 at 16:52
Here is another one that while it only does two at a time also shows different offsets and sizes also speedo differences as a result of changing sizes
All in pretty pictures
http://www.rims-n-tires.com/rt_specs.jsp
AnswerID: 370527
Follow Up By: Member - Malcolm (Townsville) - Wednesday, Jun 17, 2009 at 17:59
That's pretty cool Graham. Had to bookmark that one.
living the 'good life'
FollowupID: 637849
Follow Up By: Member - Tony & Julie (FNQ) - Wednesday, Jun 17, 2009 at 18:03
:-) Well done - There are quite a few out there - Just for fun I added a new version that will show what the speedo will read when you were doing 100k with the original tyres - So you can still do 4 sizes, but without pictures :-) Cheers Tony
FollowupID: 637852
Reply By: Gone Bush (WA) - Wednesday, Jun 17, 2009 at 18:01
Here's another one:
Site Link
AnswerID: 370541
Follow Up By: Member - Tony & Julie (FNQ) - Wednesday, Jun 17, 2009 at 18:08
Gone Bush - :-) Dont get me wrong - I know they are all there - I have found them. What I did not find is one that had more than 2 tyres at a time. There was one, but I never found it again.
I wanted to do 4 different sizes against my standard tyres.
Well at least we will have a post with all the best tyre calculator sites :-) Cheers Tony
FollowupID: 637854
Follow Up By: Gone Bush (WA) - Wednesday, Jun 17, 2009 at 18:30
No worries Tony, I hope my post didn't come across as being sarcastic, just adding to the list.
FollowupID: 637859
Follow Up By: Member - Tony & Julie (FNQ) - Wednesday, Jun 17, 2009 at 18:41
No - No worries Gone Bush - When someone does a search for tyre calculators they should get a good variety now :-) - I assume more will be on the way.
I just did not want to be seen as posting the obvious - just somthing with the ability to do more then 2.
There is a real good one I found - but I did not save the link - American I think. It had the ability to do about 6 tyres. Cheers Tony
FollowupID: 637862
Reply By: Member - Graham H (QLD) - Wednesday, Jun 17, 2009 at 18:30
Just put mine up as a lot ask about offsets so put that one up.
AnswerID: 370546
Follow Up By: Member - Tony & Julie (FNQ) - Wednesday, Jun 17, 2009 at 19:04
Graham - Where is it? I had a look and could not find. I am not good Looking :-) Cheers Tony
FollowupID: 637865
Follow Up By: Member - Graham H (QLD) - Wednesday, Jun 17, 2009 at 19:43
I'll take your word for the not good looking bit Rofl
Here it is, if you scroll down it gives speedo alterations and a list of all tyre size alternatives A lot want to fit different rims and this will give you clearances etc.
EG if you want to fit Rigid front rims to an IFS croozer
Tyre comparator with offsets and alternative sizes
FollowupID: 637869
Follow Up By: Member - Tony & Julie (FNQ) - Thursday, Jun 18, 2009 at 16:05
Graham - Ta & cheers - SCREEN DUMP SHOWS you can compare your standard & 4 others. Cheers Tony
Image Could Not Be Found
FollowupID: 637998
Reply By: Member -Dodger - Thursday, Jun 18, 2009 at 16:22
Where is the offset shown on the Rim?
Or how does one work it out?
Example my van rims read.
ROH Track 2 Wearing 235/75 R15 Tyres
Cheers Dodg.
AnswerID: 370702
