GPS help
Submitted: Wednesday, Jun 17, 2009 at 19:55
hunter40
Hi All,
I have brought a double din dvd/gps navigation unit for the patrol it comes with iGO8 maps it runs wince 5 so Lam suppose to be able to run additional maps. I would like to try OziExplorerCE I have downloaded the trail version on to a SD card but it doesn't seem to want to work it say's cant find executable file so am I doing something wrong do I need to get another programme to open it any help would be appreciated
hunter
Reply By: Member - Brad S (SA) - Wednesday, Jun 17, 2009 at 20:27
Which type of CPU does it run...MIPS or ARM?
Try each version maybe...
370575
Reply By: Bob of KAOS - Wednesday, Jun 17, 2009 at 22:06
Hunter
Does your machine have a NavSetup button (under settings)? When you click this does it show the SD card and the files on it?
370588
Reply By: chris123 - Wednesday, Jun 17, 2009 at 22:52
I assume you bought a cheap no-name unit
On
mine I select the GPS and change the navigation setup to load the other nav program
370595
Follow Up By: hunter40 - Thursday, Jun 18, 2009 at 16:46
Hi Mate'
Yeh it is a cheapie iGO8 is on a licenced sd card I have put Ozi on it but it says can't find shell file somthing like that I have also tried Ozi on a seperate card can't find exe file.
hunter
638008
Follow Up By: chris123 - Thursday, Jun 18, 2009 at 16:53
There is probably a system config file that also needs to be setup correctly, I cant help as I use iG08, try searching some forums
638011
Reply By: KennyBWilson - Thursday, Jun 18, 2009 at 00:24
I just copy and pasted the folder into the SD card and open the OziCe folder and then open Oziexplorer.exe .
There is a yahoo forums if you have any troubles.
http://groups.yahoo.com/group/Ozi-UsersCE/
370600
Reply By: Member - Graham H (QLD) - Thursday, Jun 18, 2009 at 17:36
Post a question on the gpsaustralia
forum they are the experts
370716
