Thursday, Jun 18, 2009 at 22:15
Viz,
You will find desert sand driving driving different to whatever sand driving you've done before, so I personally would not do as you suggest.
Like Stephen, I love
the desert country and have done a lot of trips out there over the past 30 odd years, and I agree 100% with his suggestions.
You seem concerned about lowering tyre pressures too far. But for
Simpson Desert travel its best to start at lower pressures because past experience says it works out there - and in addition, you'll find your vehicle will be working easier, it will use less
fuel and you can drive the dunes more slowly - many of the approaches are deeply scalloped from vehicles running too much air, and if you take them too fast, you will do damage - not just
suspension, but I've seen dual cabs with bent chassis from taking these dunes too fast. Most vehicles are loaded to the hilt out there.
I have never seen a vehicle roll a tyre off a rim in
the desert. But I've seen it countless times close to home - at
places like
Peake and
Beachport where our 4wd clubs teach sand driving.
Tyre damage is most likely to occur when travelling to and from
the desert - the bigger sharp stones on the
Oodnadatta,
Birdsville and Pedirka tracks will easily penetrate the tread if you travel too fast, with too much pressure, too much weight or with tyres that are >50% worn. Its rare to damage a tyre on the central tracks in the
Simpson Desert.
638075
