battery charging
Submitted: Sunday, Jun 21, 2009 at 12:51
al
hi all
just installed a battery in caravan. tug is a gq patrol with aux. bat. standard alternator . will this be able to recharge all 3 batteries and run a three way fridge while driving about six hours a day ? having a few beers with mates and the general consensus was that i may need a second alternator fitted or a bigger output alternator. what are your thoughts on it ?
have a nice day
al
Reply By: olcoolone - Sunday, Jun 21, 2009 at 13:29
Yes it will charge 3 batterys OK.
I would use a RanOx to charge the battery in the van and Tee of to the fridge before the RanOx with a relay that can be controlled from the RanOx to switch on the fridge when the vehicle is running.
The RanOx is a DC-DC 3 stage 25 amp battery charger that can also controll out board relays as for the fridge.
You don't want your fridge running on DC whilst you are mot driving.
371162
Follow Up By: Member - Chris & Debbie (QLD) - Sunday, Jun 21, 2009 at 13:43
I would second the Ranox, they are a great bit of kit that works as advertised.
You will find they are a very helpfull mob, send an email and ask to be emailed the setup and operating instuctions.
Chris
638449
Reply By: ABR - SIDEWINDER - Sunday, Jun 21, 2009 at 16:59
Hi Al
What type and size of battery did you fit ?
What size cables are fitted between the cars aux battery and the caravan battery ?
There are battery-to-battery chargers like the Ranox and our new 30A DC-DC 4 stage battery charger.
The most common way to charge the battery is heavy cable and plugs and a dedicated circuit for the fridge.
Have a look at the article section for more info on this.
Derek from ABR
371195
Follow Up By: ABR - SIDEWINDER - Sunday, Jun 21, 2009 at 17:10
638487
