100 series no brakes after front pads changed
Submitted: Sunday, Jun 21, 2009 at 18:51
peejay
have fitted new front brake pads and now the pedal goes almost to the floor
Reply By: Member - Stuart P (WA) - Sunday, Jun 21, 2009 at 18:55
be careful beeding the brakes .the abs system does not allow bleeding via old methods of pumping the pedal,
371209
Reply By: rapid80 - Sunday, Jun 21, 2009 at 18:56
Did you bed them in ?
371211
Reply By: GerryP - Sunday, Jun 21, 2009 at 18:59
Hi Peejay,
Pump the pedal a few times and it should come back up. Start the car and let the ABS gizmo do it's thing and it should be OK. If not, then there's something else wrong - like somehow air has gotten into the system. This shouldn't happen unless you popped a piston in the caliper or run out of fluid.
The first few pumps always go down to the floor to '
seat' the pads against the disk after prising the calipers apart to fit the new bits.
Hope it's all good.
Gerry
371213
Follow Up By: disco driver - Sunday, Jun 21, 2009 at 19:13
Make sure that the brake mastercylinder fluid reservior is completely full before you start pumping the pedal.
It doesn't take much pumping for the fluid level to drop considerably.
Disco.
638508
Reply By: Member - Toyocrusa (NSW) - Sunday, Jun 21, 2009 at 19:56
Hi peejay. Have a look on the master cylinder fluid resevoir. There are instructions on how to pump up the brake pedal to deactivate the abs unit. If the pedal still goes down afterwards you may have to search on www.lcool.org
Otherwise it may mean getting a Toyota dealer to repressurise the system. Regards,Bob.
371225
