HJ60 NOISE
Submitted: Monday, Jun 22, 2009 at 16:29
ThreadID: 70060 Views:2198 Replies:4 FollowUps:3
Hi Everyone
I have a 1985 HJ60 Sahara which has developed a high pitch squeal at idle when it warms up. I have looked for suspect but it is hard to track down. I am starting to suspect the clutch pressure plate but not sure. Anyone had any experience with this. I had a second HJ60 awhile ago which had a similar noise but I sold it before I got to the bottom of the problem?
Rob
Reply By: Member - Ian H (NSW) - Monday, Jun 22, 2009 at 18:57
Try spraying the fan belt with water. If the noise stops immediately you have got the answer. If not then try pushing in the clutch pedal while car is stopped but in gear. If it squeals then it is the spigot bearing in the end of the crankshaft. Good luck.
AnswerID: 371365
Follow Up By: Member - Rob - Monday, Jun 22, 2009 at 19:36
Thanks Ian,
I will give it a try.
Rob
FollowupID: 638646
Reply By: peejay - Monday, Jun 22, 2009 at 19:06
noise could be from a number of problems,need more information,is the noise there all the time,does noise vary when hot,or you use lights or air con,or clutch.
AnswerID: 371368
Follow Up By: Member - Rob - Monday, Jun 22, 2009 at 19:44
Hi Peejay,
All fixture and fittings under the vehicle have been checked for being loose. When cold the noise is not there. When warmed up the noise starts. Does not appear to be related to lights and definetly the aircon. If I am sitting at the lights and knock her out of gear and have the clutch out you can hear the noise. While sitting there if I raise the revs the noise goes away. Then when I take my foot off the accelerator the noise comes back. Sometimes I can hear it when I am changing gears as the revs drop whilst the clutch is engaged to change gears.
Any suggestions would be welcome.
Rob
FollowupID: 638647
Reply By: Member - Rob - Monday, Jun 22, 2009 at 19:45
Peejay
Definitely not he aircon. Sorrry about that.
Rob
AnswerID: 371380
Reply By: franken - Wednesday, Jun 24, 2009 at 12:40
my experience says to check the bearings in any idler/tension pulleys.
frank.
AnswerID: 371643
Follow Up By: Member - Rob - Wednesday, Jun 24, 2009 at 16:09
Thanks Franken
Will check it out
Rob
FollowupID: 638920
