how would it go
Submitted: Monday, Jun 22, 2009 at 17:40
Mopar
G'day all looking at going out to
birdsville(from
brisbane area) and then down the
birdsville track.We'll be towing a jayco outback poptop but i have been told the road from
windorah to
birdsville may be to ruff for the van.Planning to go about two weeks before the
birdsville races.Won't be going flatout driving to the conditions etc.So how would we go any comments greatly appreciated.
Reply By: Member - beachbum - Monday, Jun 22, 2009 at 17:46
Just go for it. If, as you say, you will drive to conditions you will not have any problems. Make sure you have a look at Dion's
lookout.keep your tyre pressures a bit lower than for the black stuff though.
371357
Reply By: Member - Shane D (QLD) - Monday, Jun 22, 2009 at 19:11
Good tyres and some sort of protection screen between van and the rear of your vehicle if you like your rear windows.
Shane
371370
Reply By: Mopar - Monday, Jun 22, 2009 at 19:37
Thanks for the replies.I thought we would be right as along as we poke along.Getting new tyres for the trip.
371375
Reply By: toyotabits .........VKS-737 ...mobile 2629 - Monday, Jun 22, 2009 at 20:37
G'day mopar, 15 years ago we did the whole
birdsville track in a standard 1978 falcon wagon,
Birdsville to
Adelaide, only 5 punctures ( no ground clearance) we carried extra tubes in case, now it is a serviced road - little challenge! we did
Birdsville races, Maree,
Adelaide,
Broken Hill,
Louth,
Brisbane in 8 days & enjoyed every minute, have a go! extra tubes & changing practice may help, have fun, regards, aussiedingo
371389
Follow Up By: Member - Doug T (NT) - Tuesday, Jun 23, 2009 at 16:46
5 Punctures in that short distance , In 1967 in my 62 EK I went from Waikerie (home) to
Perth,
Carnarvon (end of sealed road to
Darwin), Wittenoom,
Marble Bar, Pt Hedland,
Darwin,
Alice Springs,
Oodnadatta, Maree, to Waikerie, had only 1 blow out and that was in the usual section I always seemed to get one, between Liegh
Creek and
Hawker, the tyres were Goodyear G800's , Radial's hadn't been on the market all that long then,
638751
Reply By: Nomadic Navara - Tuesday, Jun 23, 2009 at 01:23
If you think the
Windorah -
Birdsville stretch is a bit rough then don't go south from
Birdsville. In the last week I have driven
Windorah -
Birdsville -
Boulia. I have a standard pop-top on a Preston chassis. I drove the gravel stretches at speeds over 70 km/h for all but a couple of kilometres on the way to
Birdsville. The only poor roads I struck were in the
Boulia Shire but you will be wholly in the Diamantina Shire.
371429
Reply By: GypsyOne - Tuesday, Jun 23, 2009 at 07:30
I have recently returned from traversing the
Birdsville track, S to N and passed a Getz towing a Cub camper. After seeing that I reckon anything is possible.
Mind you the first 90klms or so south of
Birdsville is pretty good but after that the road gets a bit rough and has plenty of rocky shaly sections.
We had a piece of 3 ply on the rear window for protection (worked a treat) and definitely lower your tyre pressures. Lower tyre pressures will help but is not a guarantee; we still did a tyre on the CT on the
Birdsville Track.
The races are in September so in August when you are planning to travel might have the road conditions completely different. Check again closer to the time you plan to travel.
371434
