HF Multi Tap Antenna Tuning
Submitted: Friday, Jul 03, 2009 at 00:31
ThreadID: 70355 Views:6700 Replies:6 FollowUps:3
Hi guys & girls, i'm in the process of installing a HF radio to my fourby, but the wire on the antenna has been unplugged from the taps & i'm buggered if i can remember what ones to plug it in to... Can anyone tell me please? Need to know asap as i'm heading to Cape York on Saturday & want to have it done by then.
Cheers, Brad
Reply By: Member - Tony S (WA) - Friday, Jul 03, 2009 at 01:08
Here is your change for what it is worth.
Have a look at the RFDS web site, they should have the stations listed . However they may relay to H.O. so, which ever is closest to the big finger will be relaid. ie Charleville.
Tony
The rig
AnswerID: 372865
Reply By: Richard Kovac - Friday, Jul 03, 2009 at 02:26
Brad
The bottom plug stays where it is and you wind the tap (wire with plug on it) into the plug you need to listen too. eg vks 2 vks 5 etc. wind the wire around the pole as you feed it.
VKS-737 channel 2 is what you should leave it on and change it to Channel 1 during skeds
Richard not grumps
AnswerID: 372866
Reply By: Member - Stephen L (Clare SA) - Friday, Jul 03, 2009 at 08:28
Hi Brad,
Like above, the bottom tap wire is always installed into the bottom tap of the Antenna,just wind the wire to the required tap that has the frequency that you require. The only time that you did away with all the taps and the wire was in the case of an emergency, and would trigger the emergency call bottom, which would transmit on frequency 2020. Do not rely on contacting the RFDS, as they did away with log in calls years ago. Back then you had to have a Mobile Outpost Radio Licence, then register that call sign with any RFDS base that you wanted to talk to.
I hope that you have a VKS-737 licence, as their service is second to none with the best base station layout across Australia.
Have a great trip.
AnswerID: 372880
Follow Up By: Member - Mike (SA) - Friday, Jul 03, 2009 at 09:24
One important additional point - wind up the pole clockwise!
Mike
Too little time in the bush!
VKS 737 Mobile 0230
FollowupID: 640135
Follow Up By: Member - Tony S (WA) - Friday, Jul 03, 2009 at 17:33
Gud-day Stephen
I assumed that Brad was talking emergencies.
My set came out when Adam was a boy and is an old crystal job with the arial tapped to a numerous RFDS stations through out Aust.
Still works too, got used last year for a serious car rollover.
Tony
The rig
FollowupID: 640181
Reply By: Member - Tezza Qld - Friday, Jul 03, 2009 at 10:00
Hi If your antenna is marked in frequencies you would be looking for 8022 or 5455. If you only have the taps numbered different problem. On one of my antennas that is numbered 1-16 tap 11 is 8022 and tap 7 is 5455. Apart from that trail and error during sked times. As long as you dont transmit no damage should be done. Good luck and enjoy the cape ,it;s a great trip.
Teza
AnswerID: 372892
Reply By: Member - Littleborgy (SA) - Friday, Jul 03, 2009 at 10:20
Thanks Guys, just the info i was after
Cheers, Brad
AnswerID: 372895
Reply By: Member - joc45 (WA) - Friday, Jul 03, 2009 at 13:09
Hi Brad,
Sometimes a passing branch or whatever can damage or destroy the original wire. The length is critical, and if you have to repair the original, you may not get the correct length again.
As a useful backup, I suggest you carry a replacement wire with banana plugs. Some insulated automotive copper wire, similar to the original, fitted with banana plugs at the ends and cut to exactly the same length as the original. The plugs are avail from Dick Smith's, Jaycar, etc. Just make sure you get good-quality plugs, pref silver-plated, as the cheapies tend to fall out.
Colour of both wire and plugs is optional :D
Gerry
AnswerID: 372910
Follow Up By: get outmore - Friday, Jul 03, 2009 at 14:40
the length of the lead will be denoted somwhere around the bottom of the ariel and it will start with WL then a figure in cm for the length of the Wanda Lead
FollowupID: 640164
