Blown Head Gasket - Land Cruiser, 80 Series
Submitted: Friday, Jul 03, 2009 at 14:25
ThreadID: 70360 Views:12354 Replies:5 FollowUps:3
My 1994 LC80 (249k kms on the clock) has blown a head gasket, hopefully not cracked the head, and I'd be most interested to hear from any other LC owners who may have had a similar problem, and the extent of repair work that ensued.
With thanks,
Dick
Reply By: Member - Old Girl (QLD) - Friday, Jul 03, 2009 at 14:33
Rebuild for us. The word marked bore comes to mind & dust. Ours 92 with 330 on the clock. went through the elimination process first. Radiator and the list goes on.
AnswerID: 372917
Reply By: get outmore - Friday, Jul 03, 2009 at 14:36
in my experience vehicles rarely blow head gaskets - but they often crack heads
petrol or diesal?
AnswerID: 372920
Follow Up By: Member - DickyBeach - Friday, Jul 03, 2009 at 14:55
Sorry guys, I should have indicated it's a Petrol engine.
Why would they crack heads rather than blow gaskets?
FollowupID: 640169
Follow Up By: get outmore - Friday, Jul 03, 2009 at 15:01
I dont know its not just cruisers - any vehicles. seen/heard of plenty of cracked heads but not to many gaskets
FollowupID: 640171
Reply By: Member - DOZER- Friday, Jul 03, 2009 at 16:08
Common on this motor at this kms.....i did mine at those kms, and the reason is....alloy head stretches head bolts each heat cycle, and sooner or later they loose tension when cold, and gas starts to leak across when cold...gets worse as gasket errodes....till u start to miss at startup. Thats what happened to mine anyway, 1700 had a reco on the head and new toyota gaskets and head bolts ($35 each)
After me, another went on a mates cruiser (4.5) he bought a gasket and tightened the head back down to spec torque plus an extra 1/4 turn.....its still going. So it depends on whether you overheated at all or just started to notice bubbles....if the later, a new gasket and new bolts (aftermarket are $65 a ser) would do...but that would depend on the valves being in spec for clearance...if they r out, you might aswell get the head service done (350) and another 350 to set the valves whilst all appart, or play with shims when its back together......which is a PITA as you need to buy the shims from Toyota.
Andrew
AnswerID: 372929
Reply By: Wherehegon - Friday, Jul 03, 2009 at 16:18
Is it running LPG ??? Regards Steve M
AnswerID: 372935
Follow Up By: Member - DickyBeach - Saturday, Jul 04, 2009 at 00:18
Petrol, my friend
FollowupID: 640225
Reply By: Member - DickyBeach - Monday, Jul 06, 2009 at 06:29
Thanks to all for your replies, I'll now wait until I hear from ARB as to the problem, fingers crossed for only a head gasket.
Dick
AnswerID: 373267
