LED lighting
Submitted: Sunday, Jul 05, 2009 at 21:13
touringoz
I am looking at replacing the small 1 inch Halogen globes (reading lamps) in my Coromal Van with these
http://www.ledshoponline.com/G4_LED_bulb.htm
was wondering if anyone else has tried these and are they the correct ones.
fergy
Reply By: Member - Joe F (WA) - Sunday, Jul 05, 2009 at 23:33
G'day Fergy
I have replaced most of the 12V Halogen lights in my Coromal with 12V LED light cluster units, they are the same two pin set up as the Halogen lights, but give a softer blue~ish light, but I have retained the Halogen lights in the range hood, as the blue~ish LED light gave the food being cooked at the time a strange (visual ) look.
The on board battery monitor for the Solar charging system, definitely shows a reduced output from the batteries with the LED's as opposed to the Halogens when used.
The LED's are as dear as poison compared to the Halogen globes, but there have not been any failures in 3 years with the LED's.
Regards.
373259
Follow Up By: Member - Mike DID - Tuesday, Jul 07, 2009 at 10:24
"but I have retained the Halogen lights in the range hood, as the blue~ish LED light gave the food being cooked at the time a strange (visual ) look. "
- you need to make sure you get "Warm White" LEDs rather than "Natural" or "Daylight" to avoid this bluish light.
640572
Follow Up By: Member - Willie , Sydney. - Tuesday, Jul 07, 2009 at 16:42
Couldn't be Maria's cooking could it Joe ?
Willie
640602
Follow Up By: Member - Joe F (WA) - Tuesday, Jul 07, 2009 at 19:22
G'day Willie
Nice to know you are still lurking around ~ no mate the wifes cooking is perfect almost all of the time, as Mike DID, correctly stated the colour of the LED's was the cause of consern at the time.
Nice to hear from you ~ stay in touch Willie.
Regards joe
640625
Follow Up By: Member - JohnR (Vic) - Wednesday, Jul 08, 2009 at 08:29
Willie, you are trying to "off side" the
cook are you? Careful on the tackle mate. LOL
640684
Reply By: Boobook2 - Monday, Jul 06, 2009 at 06:52
Fergy, I replaced the original bulns with these and they are brighter, they just plug in. Make sure you have G4 though and get the more expensive ones at the bottom of that page.
G4 regers to the distance between the leads. The bulbs are usnally a small bulb shape with two pins.
If you have the standard downlights ( MR10, MR16, Gu5.3) then these wont fit.
373268
