Fuel filter housing Nissan Patrol - manual prime - Fault
Submitted: Thursday, Jul 09, 2009 at 10:42
Ozboc
Greetings guys -- ran a few keywords in the find -- nothing comes up - though i remember maybe 1 year ago this may have been discussed .... anyway
My nissan has been playing up --- 1 st gear - runs through the revs fine past turbo kick in point --- upto to 3k rpm easy --- 2nd 2 k rpm struggles at Turbo
3rd -- does not make turbo easy -- has to wind up slowly without putting foot to much into it ....
fuel starvation ......
I check the little inline filter i have after the main z332
fuel filter ( its a sight glass type ) and can see
fuel intermittently going in and through -- not even filling the glass when running .... push the Prime button a number of times - can hear a air sucking sound ..... - take
fuel inlet to filter block off -- pump primer -- hardly no suction at all ( to none ) so its leaking air / sucking air
put inlet
fuel line direct to my inline filter - ( bypass main filter ) took for a run -- fully loaded each gear -- runs perfect ......
Now that i have worked out the process of elimination ( may help others in the future ) My question is - is this an after market part - can i get from repco/arb or other such
places or is this nissan specific ?
thanks
Boc
Reply By: Member - Roachie (SA) - Thursday, Jul 09, 2009 at 11:04
Boc,
So let me check what you have deduced? You now believe the priming unit that the original filter mounts on, is stuffed?
If so, there may be a kit you can purchase to replace O rings etc and get it back up to spec.
However, I'd be inclined to check that it is definitely buggared before proceeding. Check that the filter is not blocked (by installing a new filter) and that the rubber hoses are not damaged/split etc.
I have actually replaced my main filter housing with a CAV filter which has it's own plunger/primer, similar to the original. There is nothing wrong with my original filter housing, it's just that the CAV filters are much cheaper and readily available in remote locations. I actually have an extra CAV filter housing fitted to my Patrol too, but it doesn't have a primer. I also have fitted an electric lift pump to push the
fuel from the
tank up through these 2 filters (as
well as a Morrison De-Bug unit....cos I love clean diesel).
If you are interested, I'd be willing to sell my original Nissan filter housing to you for , say, $100- plus postage...... (just a thought; I'm not trying to tout for a sale here...hahaha)
Roachie
373729
Follow Up By: Member - Roachie (SA) - Thursday, Jul 09, 2009 at 11:07
Sorry, forgot to mention............... there is also a possibility that the fact that you have 2 filters in line, the injector pump might be struggling to suck the
fuel through the extra resistence that the extra filter creates.
If so, you may just need to fit a Facet pump or similar electric assistance pump.
Roachie
640873
Reply By: Ozboc - Thursday, Jul 09, 2009 at 11:08
HI - thanks for your rply --- should have mentioned that i put a brand new filter on this morning as this was my first impression ( blocked filter ) when i emptied the contents of the old filter out ( after a GOOD shake to stir it all up ) the diesel came out clean .... replaced anyway ...
I am thinking of going the aftermarket housing-pump now --- rycor i think there named -- used to use them years ago
just going to give nissan a ring to see if they need me give my left arm for a replacement unit before i decide
Boc
373730
Follow Up By: Ozboc - Thursday, Jul 09, 2009 at 13:15
well rang nissan ---- $385 JUST for the top housing -- a quick look on ebay shows 10 micron filters COMPLETE with
water bowl ( clear ) and housing with priming pump, it does not have provision for the
water switch but i can live with that as a visual inspection is easily done ,..
ebay filter link
Might be the way i go ---
Boc
640890
Follow Up By: Member - ross m (WA) - Thursday, Jul 09, 2009 at 13:52
i would check the flow rate before buying.
Some diesels suck much more diesel than they need to keep the injector pump cool and then recycle it back to the
tank
My 1HZ pulls through up to 46 litres and hour according to the FSM so I imagine a Patrol would be much the same.
I have a Delphi 296 with primer and its borderline on the flow rate
640891
Follow Up By: Ozboc - Thursday, Jul 09, 2009 at 14:12
2 steps ahead of you -- its 227 l per hour -- i have also emailed the guy asking if this is suitable for Nissan Patrol 4.2's - he sells a lot of diesel stuff mainly for toymotas and Nissan ... so should know ....
thanks for your reply
Boc
640898
