Sub Tank Question
Submitted: Saturday, Jul 11, 2009 at 09:35
ThreadID: 70573 Views:2938 Replies:5 FollowUps:12
gday all
just had a call from the Borgy's, they are at Cairns at the moment and having trouble with their sub tank. Dave said it took him 10 minutes to put in 5 ltrs of deisel.he said the breather tube is clear and unblocked but cant see why the fuel wont go in. the fuel just keeps running back up the filler tube.
Does anyone have any ideas as to why he cant fill his tank?
I will give him a call back if anyone can shed some light on this,cheers.
Reply By: Member - Fred B (NT) - Saturday, Jul 11, 2009 at 10:13
diesel or petrol?
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 374037
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Jul 11, 2009 at 10:29
diesel!
FollowupID: 641228
Follow Up By: Member - Fred B (NT) - Saturday, Jul 11, 2009 at 10:37
sorry, but other than the breather tube still being the problem, I can't shed any light on the problem for you. Only thing I can think of is: the breather tube is partially compressed somewhere, therefore restricting flow of air.
regards,
Fred B
FollowupID: 641230
Reply By: Member - Graham H (QLD) - Saturday, Jul 11, 2009 at 10:37
If its a 100ser croozer mine is like that. Can put about 80 litres in then its as slow as spits and coughs and takes ages to put the rest in.
Is the same for both tanks
Seems to be that the breathers run together and dont let the tanks vent properly.
Have been going to ask a serviceman about it at next service
AnswerID: 374043
Follow Up By: Member - Kiwi Kia - Saturday, Jul 11, 2009 at 10:48
Also, some of those tanks only like a slow fill rate. If you try and fill from a high flow rate truck bowser the diesel will foam up and blow the fuel out. You can try filling very slowly or move over to the main forecourt and use the slower filling pump.
KK
FollowupID: 641231
Follow Up By: Bonz (Vic) - Thoughtfully- Saturday, Jul 11, 2009 at 12:25
Pretty sure its a Patrol
FollowupID: 641238
Follow Up By: Member - Shane D (QLD) - Saturday, Jul 11, 2009 at 20:01
How old is your Cruiser?
I have an '05 poverty pack with STD tanks and never had a problem with using hi-flow pumps, I have heard of older 100's having similar problems with filling and maybe there was a suttle change when the updated 100's came out in '05.
Shane
FollowupID: 641320
Follow Up By: Member - Graham H (QLD) - Saturday, Jul 11, 2009 at 20:07
Its a Feb 2005 GXL and is the slowest car to fill out of the 36 different ones I have owned
FollowupID: 641322
Follow Up By: Member - Shane D (QLD) - Saturday, Jul 11, 2009 at 20:18
Mine's November "05 (updated mod).
I don't know if they changed anything or not, But Mine can take whatever the bowser can give to either tank.
Maybe worth mentioning at next service.
Shane
FollowupID: 641325
Follow Up By: Member - Duke (TAS) - Sunday, Jul 12, 2009 at 21:06
Mine is a Nov06 100 Series Cruiser and sometimes does as yours Graham H. Seems to be worse on hot days after travelling for 3 or 4 hundred kls.
Gets very frustrating when sevos are busy and people waiting.
The vehicle i had previous was a 4.2 Patrol and it was the same but had been fitted with a long range tank. I put it down to a fairly sharp bend in the rubber filler hose.
Duke
FollowupID: 641471
Follow Up By: Member - Graham H (QLD) - Sunday, Jul 12, 2009 at 21:17
I can put about 75 litres in the main tank then it foams up and gets an airblock and coughs it all up then takes a bit more and does it again
Same with the sub
If I dribble it in with liquid only and no foam its ok but takes for ever.
Seems that its not letting the air out fast enough.
Will talk to Toyota when I get back to civilisation.
FollowupID: 641474
Reply By: Sir Kev & Darkie - Saturday, Jul 11, 2009 at 10:58
Tell him the Sub Tank is full and he is having an Old Timers moment and should be filling the Main Tank LOL
Cheers Kev
Russell Coight:
AnswerID: 374045
Reply By: Geoff (Newcastle, NSW) - Saturday, Jul 11, 2009 at 13:36
Did you ask him if it was already full?
Geoff,
AnswerID: 374060
Reply By: Member - Rob Mac (QLD) - Saturday, Jul 11, 2009 at 20:20
Hello Mark, I had a 1983 Landrover LWB and it took twenty minutes to fill the tank (diesel), we found the breather hose had a downward loop below the top of the tank that filled with diesel and created a liquid lock. Re-routed the hose and no more problems.
Rob Mac
AnswerID: 374095
Follow Up By: Member - Mark G Gulmarrad - Saturday, Jul 11, 2009 at 20:51
Rob
not long spoke to Dave and he is going to check that very thing out....cheers for that :-)
FollowupID: 641329
Follow Up By: Luke SA - Saturday, Jul 11, 2009 at 23:06
Just spoke to the old man an hour ago and he said it looks like this to be the case. When he shortened the filler hose he didn't the breather. Is going to shorten it then try.............
FollowupID: 641344
Follow Up By: Member - Mark G Gulmarrad - Sunday, Jul 12, 2009 at 15:15
Rob
Dave phoned this morning and the problem was what you said.......he said to say thank you to all who replied. :-))
FollowupID: 641406
