re. camp shower
Submitted: Saturday, Jul 11, 2009 at 13:16
ThreadID: 70580 Views:4274 Replies:3 FollowUps:17
Thanks to all for the info. regarding the make it yourself camp shower request, with all that info. I found out that I can purchase a Helton complete for $249 so I think that's the way to go, at least that way I'll know that it'll work and not be another unfinished project that's going to cop a canning from "SHE WHO MUST BE OBEYED"
Cheer's,
TerryC
Reply By: Member - Ian H (NSW) - Saturday, Jul 11, 2009 at 15:35
Good idea Terry. You do need to know how to eliminate scalding from all brands of heat exchanger showers. It is a real risk. Just MM me if you want me to tell you how. Very simple and cheap.
Ian
AnswerID: 374067
Follow Up By: Shaker - Saturday, Jul 11, 2009 at 15:56
Is it a secret, or a mod that can be shared?
FollowupID: 641275
Follow Up By: Bonz (Vic) - Thoughtfully- Saturday, Jul 11, 2009 at 16:51
MM him Shaker and find out
FollowupID: 641288
Follow Up By: Member - Ian H (NSW) - Wednesday, Jul 15, 2009 at 09:23
Hi fellas,
I was replying to you last weekend when I collapsed and was rushed to hospital with pneumonia. I am home now but will reply properly when i am well enough. sorry. Ian
FollowupID: 641815
Follow Up By: Member - Allan B (QLD) - Wednesday, Jul 15, 2009 at 09:35
Gee that's no good mate!
Hope you are fully recovered real soon.
FollowupID: 641819
Follow Up By: Bonz (Vic) - Thoughtfully- Wednesday, Jul 15, 2009 at 16:28
Yer me too Hope youre back on top of that health thing sooner than you know
FollowupID: 641876
Follow Up By: Member - Ian H (NSW) - Saturday, Jul 18, 2009 at 14:40
Hi again fellas. I am back from the dead after a bit of a scare. Thanks for the good wishes that came from total strangers. What a good bunch of forumites we have!
Now to explain the set up I have attached a picture that is worth a thousand words.Image Could Not Be Found. I just previewed the post and the picture is only in text form but I will continue in case it posts normally.
Basically the output from the pump goes first to a 2 way switching valve.During heating up of the 20 litres is the jerry the water goes as normal through the H/E and then to the rose and back into the jerry. When water in jerry is hot enough the 2 way valves are changed to direct the pump output directly to the rose, completely bypassing the H/E. The can not be any scalding from water lying in the H/E during soap up, washing hair etc because that water never leaves the unit. Simple plumbing answer to a serious problem. When I first did the mod to my Twine I rang john twine and he said "what a good idea".
I in fact think manufacturers are leaving them selves open to trouble by continuing to market a product so dangerous and the trying to hide behind a sticker that warns of the trouble. Bit like Nissan saying that they know the back left wheel sometimes comes off by itself but putting a sticker on the dash warning the driver.
Ok, I will post this and see if the picture appears. If not I will try again.
Regards, IanImage Could Not Be Found
FollowupID: 642334
Follow Up By: Member - Ian H (NSW) - Saturday, Jul 18, 2009 at 14:41
Whoops, added the pic twice but better that than not at all. Sorry.
FollowupID: 642335
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Jul 19, 2009 at 19:50
Ian ... I used to run my shower heat exchange directly to the shower head, one pass from the cold container to the shower head like most do but i tried just recycling the clean water through the shower head back through the cold container of water and heated the whole container to the same temp and then turn the engine off. Now you can shower in peace and not disturb the others around you, stop, start the water and lather up and still turn the water back on to to same temp as before.. Safer for younger ones also.. I took that tip from Roachie some years back, he gets it right occasionally :)) !!! Michael
FollowupID: 642488
Follow Up By: Member - Ian H (NSW) - Sunday, Jul 19, 2009 at 20:08
yes Michael, that was what I first thought of but you still have hot coolant in the H/E until the circulating shower water cools it down. With my system as soon as the jerry water is hot enough I shut the engine down, switch the valves over and instantly and totally isolate the problem. There is NO chance of a scald especially when others are using the shower who may not be quite so aware and not really listening to instructions while contemplating stripping off somewhere strange.
I am much happier having total control over the problem and for the cost of maybe $15 and an hours work why wouldn't I be. Seems a no brainer to me.
FollowupID: 642492
Follow Up By: Member - Roachie (SA) - Monday, Jul 20, 2009 at 10:46
Thanks for the "credit" Michael.... hahaha
My idea is slightly different and wouldn't be possible if the supply hose was coming directly from a gerry can.
We actually decant the jerry can of water into a large 20 litre "nappy bucket" which is placed in the shower tent. The water is recycled through the heat exchanger until it is hot enough, then the engine can be switched off. The shower head/rose does have a on/off slide button to control water flow, BUT WE NEVER TURN THE WATER OFF using this control, as it is THAT action which has the potential to scald the user.
Instead, we simply drop the shower head/rose back into the bucket during soap-up etc and the water continues to circulate. This would not be possible if your supply water was being drawn directly from the jerry can (it's a bit hard to drop the shower head into the jerry can...hahaha).
So, by doing things this way, I have negated the need to add more plumbing under the bonnet (knowing me I'd stuff it up anyway)....
Roachie
FollowupID: 642588
Follow Up By: Member - Ian H (NSW) - Monday, Jul 20, 2009 at 11:45
Hi Roachie. Yes you right. That obviously works as long as the flow is maintained. We use the on/off slider on the rose to stop the flow during soap up etc. We usually have others using our shower as well as ourselves and I was concerned about scalding so "eliminated" any possibility. I agree with "a bit less plumbing under the bonnet", that's for sure.
FollowupID: 642610
Follow Up By: Michael ( Moss Vale NSW) - Monday, Jul 20, 2009 at 19:11
Ian, The extra hoses is my main concern. All original hoses are supported and cant rub on anything so anything you add has that potential. My heat exchange, its 600mm long and sits on the bash plate inside the bull bar so i have fairly long hoses to chech for rubbing every now and then. I really believe, the simpler the better. As for the heat exchange, i dont see the cooling down a problem, as soon as the engine stops, the engine water stops so equalising the both sides of the exchange is very quick.. I guess thats whats good about everyone doing things a bit different, we can always gain something from each other. regards Michael
FollowupID: 642686
Reply By: Bonz (Vic) - Thoughtfully- Saturday, Jul 11, 2009 at 16:51
Camping stores have a $24.95 thing that plugs into the cig lighter and does the job for me.
AnswerID: 374072
Follow Up By: Member - Allan B (QLD) - Saturday, Jul 11, 2009 at 18:43
I agree Bonz. One kettle of hot water + one kettle of cold water into a plastic bucket, shower head attaches via suction cup to side of Troopy and voila, a 2 minute shower of pre-determined temperature. Works a treat and costs $25.
Oh, ............ and no need to be running the engine.
FollowupID: 641315
Follow Up By: Bonz (Vic) - Thoughtfully- Saturday, Jul 11, 2009 at 18:56
When my wife is showering my engine is ALWAYS running Allan, but I know what you mean :0)
FollowupID: 641316
Follow Up By: Member - Allan B (QLD) - Saturday, Jul 11, 2009 at 22:34
LOL Bonz!
FollowupID: 641342
Follow Up By: Member - Johny boy (NSW) - Sunday, Jul 12, 2009 at 08:47
Ah Bonz,you are a very naughty boy !!! LOL!!
FollowupID: 641352
Reply By: Member - Johny boy (NSW) - Sunday, Jul 12, 2009 at 08:54
Hi Terry ,
I was just wondering if that was the one that I told you about on E bay ,did you contact Klaeton ,as I cant remember the name Helton? the reason I'm asking is that I'm also trying to decide on a set up :)
AnswerID: 374150
Follow Up By: terryc - Sunday, Jul 12, 2009 at 20:51
G'day John,
I got a reply from someone " can't remember who" about a Helton ,so I went to the Helton site on heat exchangers and come up with the shower all inclusive for $249 "Maybe that was in yank $ I had better check". I also checked Twine and Glind but was impressed with the Helton so I'll do a bit more home work on it. It will have to wait for a month though as I'm off to out back Qld. on Tuesday, to bloody cold in Southcoast Vic.
TerryC.
FollowupID: 641469
