How sensitive are you to noise change in your vehicle??.
Submitted: Saturday, Jul 11, 2009 at 19:28
Member - Axle
My Bro inlaw has a F250 V8 ford ex
ambulance, it makes a good camper unit, and as being a freelance muso has travelled all over the country. A couple of months ago we went away with them for a few days,. thru the day we all piled into this thing to go sight seeing, and on the first day i was freakin out at the variety of mechanical noises comming out from the intestines of this bus!!!.
Trying to be polite and carefully asking whats that noise? only to receive a answer ," Its been like it for years", and that was only one racket!..lol. The thing has done 480,000kms and all original, Some blokes are oblivious to clunks , knocks, and rattles, Me! nothings perfect but sure as hell can't drive things Thinking something stuffed .
Cheers Axle.
Reply By: Robert HL (SEQ)(aka zuksctr) - Saturday, Jul 11, 2009 at 19:59
Hi Axle,am sure you have heard the old saying,('don't touch it till it's broke') i'm sure.Lol
Bob.
374092
Follow Up By: Member - Axle - Saturday, Jul 11, 2009 at 20:07
Yep!.... But as long as you touch it when it is bloody broke!!..lol.
Cheers.
641323
Reply By: Canvas Charisma - Saturday, Jul 11, 2009 at 21:18
Hi Axle,
After being with QLD
Ambulance for over 24 years in my previous occupation I know the old FTrucks used to make some weird wild and wonderful creaks, clunks and groans. They used to get a lot of body noises especially with some of the rear modules that were installed.
Having said that they shouldn't be making any loud mecahnical type noises and if it was then it might be a good idea to have it checked out. As ambulances they lead a pretty hard life.
You can have a vehicle that has sat cold all night (prior to engine warmers) and at three in the morning is cold started and driven at very high speed to emergencies etc and this can shorten a life span a bit, and a lot develop premature oil leaks as a result of this type work. I have seen them need new brake pads every few weeks due to the harsh braking that is carried out while on an emergency run.
Hope it all works out OK.
Cheers Brian
374107
Follow Up By: Member - Axle - Saturday, Jul 11, 2009 at 21:25
Hi Brian, What you say is spot on , The only thing is its the brother in laws truck, ..So God help him..hahaha.
Cheers Axle.
641336
Reply By: Bonz (Vic) - Thoughtfully- Saturday, Jul 11, 2009 at 22:43
You get used to the noise your vehicle makes, and you would also get in tune with a "don't worry" noise as compared to a "bloody hell that sounds like big dollars" noise. If its not your and he is OK with the noises then let it be Axle let it be.
374118
Reply By: GiveItAGoGavo - Sunday, Jul 12, 2009 at 01:48
I hate myself for it, but I am way over-sensitive to noises.
Ill hear a noise that I may
well have heard before and will start to wonder about it, then spend hours researching it!
Its like I have vehicular-hypochondria! :)
374133
Reply By: landed eagle - Sunday, Jul 12, 2009 at 09:22
A mate of
mine builds engines for rail dragsters. Hi motto is "a V8 always sounds at its very best, just as it's about to drop its guts all over the road".
I used to have a 302Cleveland in a panel van that made occasional noises and always knocked at start up. Never gave me any trouble in the eight years I owned it.
374156
Reply By: Member - ross m (WA) - Sunday, Jul 12, 2009 at 10:23
It depends on what type of noises they are,but generally if i cant get rid of them without great cost,I get rid of the vehicle.
I cant drive along and blissfully ignore signs of wear.
Fixing them when they 1st appear will ensure a longer life from the vehicle.
If the F250 is a 2wd,half the clunks are probably from the steering joints
374167
Reply By: Member - Damien L (Cairns) - Sunday, Jul 12, 2009 at 13:20
Hi all,
It was told told me many years ago that if you drive any car all the time you don't realise when things are going wrong. It was said that you should have someone else drive your car on a run, they will pick up any problem that you will miss because it has come wery slowly.
I get someone else to drive my truck every few months so any fault can be noticed before it gets too costly.
374187
Reply By: Richard Kovac - Sunday, Jul 12, 2009 at 22:04
Drive a 70 series then you will under stand :-)
374248
