Diesel Patrol not starting
Submitted: Monday, Jul 13, 2009 at 19:53
ThreadID: 70646 Views:2326 Replies:3 FollowUps:3
Hi all looking at purchasing a 4.2 Diesel GQ Patrol that sometimes doesn't start unless you physically rock the vehicle, starter motor has been replaced, it sound like the pinion doesn't engage.
Reply By: Member - Graham H (QLD) - Monday, Jul 13, 2009 at 19:57
Maybe the ring gear is stuffed and locks the pinion in.
AnswerID: 374386
Follow Up By: Member - Roger S (WA) - Monday, Jul 13, 2009 at 22:04
How much would I be looking at, roughly, to replace/fix the ring gear? Thanks.
FollowupID: 641636
Reply By: Member - Andrew L (QLD) - Monday, Jul 13, 2009 at 20:48
What was the starter replaced with..?..and what kilometreage is the motor..?..
a second hand unit, a reco or new one.. if the 2 latter ones, I would also call the ring gear on the flywheel...
AnswerID: 374392
Follow Up By: Member - Roger S (WA) - Monday, Jul 13, 2009 at 22:06
The starter motor was replaced with a new one. In which case how much would replacing/fixing the ring gear on the flywheel cost? The motor was replaced about 120,000 km ago with a TD 4.2T GU motor, the overall mileage on the vehicle is about 400,000 km. Thanks
FollowupID: 641638
Reply By: Foxhound (WA) - Tuesday, Jul 14, 2009 at 10:14
To replace the ring gear requires the removal of the gearbox and clutch.
AnswerID: 374463
Follow Up By: Member - Roger S (WA) - Thursday, Jul 16, 2009 at 23:37
Hi everyone who replied thanks for your help it appears that the ring gear is the most likely issue.
FollowupID: 642163
