Thursday, Jul 16, 2009 at 23:34
Hi John,
Yeah My father had a somewhat similar method but called it the "follow the trailer" method.
When backing the trailer he had me watch the mirrors (never the turn the head or open door and look back thing). If the trailer starts moving to the drivers side then turn the wheel that way slightly. This causes the ass of the car to pivot that way and the trailer goes straight again. If the trailer starts moving left then steer left and it will correct.
Using this method you can travel backwards pretty quick using only subtle steering inputs. The trick is to correct even the most subtle movement of the trailer. If it is going left the follow it left and it straightens instantly. As it straightens then you centre the wheel. If it goes a bit far and starts going right then follow it right with the steering wheel.
This works really
well if you have a small trailer that you can't really see in the mirrors behind a wide tow vehicle. As soon as you even SEE the trailer emerging on one side then steer that way until you see it come out the other side and so on. It may look ugly but is effective.
Of course you also have to process the bigger picture with peripheral vision to keep it heading in the right direction of where you are trying to reverse into but after some practice I have found that even backing around corners is easy using this "follow" method. If it is turning too quickly turn some more lock on in that direction to lessen the swing.
Also if the trailer is going around too far don't be afraid to stop and go forward just a small amount before continuing to back up. Many times I see people reversing a box trailer up a driveway and they get halfway up the drive and it all gets crossed up. They then go forward to straighten it up again but invariably go way too far and effectively start all over again. It only generally needs a few feet to straighten up to a point where you can continue reversing.
I have now got to the point where I enjoy the challenge of reversing into a driveway off a busy street without holding up traffic. A few years ago I would have been bleep ting bricks at the thought!!
Muddy
642162
