Patrol GU Speaky Belt (canary under the bonnet)
Submitted: Thursday, Jul 16, 2009 at 22:07
Troo Bloo
Hello All,
I have a 2005 GU Patrol 3.0 lt Diesel, the fan belt is sqeaky, like a canary is under the bonnet. I have replaced the belt (non-genuine) and the noise went away for a couple of days and then came back. So I then i put soap on the belt and the noise went away for a couple of days. Now it is back again, Nissan have mod that can be carried out which involes replacing
water pumps, pulleys etc which is not really practical. Has anyone had this problem? If so how do i fix it?
Any help greatly apprecaited.
Troo Bloo
Reply By: Member - Ed. C. (QLD) - Thursday, Jul 16, 2009 at 22:32
If you're satisfied that the tension is correct, I've had good success shuttin' up noisy belts by rubbing a stick of chalk (of the blackboard variety) on as much of bearing surface as ya can get at... Usually lasts quite a while before they start doin' it again... ;-)
Give it a try, and see how ya go..
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
374869
Reply By: muzzgit - Friday, Jul 17, 2009 at 00:23
The 3.0 patrol is
well known for this. My 2000 model did it at about 90,000 and it was the belt tensioner pulley thingo.
It's a bugger to get to. It is not a simple job!
There's quite a few tales about it if you want to do a search.
My buddy has a 2005 model with 100,000 and he's just been through the same thing.
374875
Reply By: Roughasguts - Friday, Jul 17, 2009 at 00:39
I have pretty good results with spraying armour all on the belts.
Never had them slip or deteriate.
Lately Been using silicone spray hoping the noise stays away longer, not sure if it's longer but it does stop the belt from squeeking.
Dad use to use a bar of soap and run that in while the motor was running!
I wouldn't recomend that practice Ouch!!!
But don't use WD 40 or similar the solvents eat rubber, where as the above preserves it.
374877
Reply By: Mike GU - Friday, Jul 17, 2009 at 02:32
Hey Troo Bloo, maybe the idler pulley, cost about 60 bux and you need to remove the fan shroud and use a T50 star to get it off, unfortunatly you cant just buy the pulley alone you must purchase the belt tensioner with it as a unit, ZD30 should go through one every 60k-90k depending on your driving, i had the same problem... could "feel" a noise from the passenger side floorpan and about 10K later SNAP!! grrrrrr
The pulley bearings wear and cause the drive belt to slip on the pulley creating the noise.
Remove the belt and tap/shake the pulley, if there is any give in it then i'd be replacing it
Good luck and i hope this helps
Mike
374880
Follow Up By: Member - Bentaxle - Friday, Jul 17, 2009 at 22:35
Mike
Repco sell replacement pulleys for $80.00 which is a lot cheeper than paying $300+ for a complete unit from Nissan.
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
642277
Reply By: 3.0turbob - Friday, Jul 17, 2009 at 09:43
Have a look at www.patrol4x4.com/forum/ and find the GU Patrol referance document. It details how to replace the bearing in the tensioner.
374901
Reply By: Member - Dennis F (WA) - Saturday, Jul 18, 2009 at 11:24
I also replaced my belt with a non genuine one and found the squeal had started.In the end after trying different things i put a Nissan genuine belt back on and the squeal was not there anymore.Since then i have heard of other non genuine belts doing the same thing.
375033
Follow Up By: Troo Bloo - Saturday, Jul 18, 2009 at 18:17
For the price of a new belt, i will give it a go and keep the other as a spare.
thanks
642363
Reply By: Member - Bucky, the "Mexican"- Sunday, Jul 19, 2009 at 04:32
Troo Bloo
Try this thread..........ThreadID: 70004
There may be some additional onfo there
Bucky
375132
