Friday, Jul 17, 2009 at 14:25
I would be curious about the relacement head.
They normally last the life of the motor from what I have seen.
Im guessing the replaced radiator has something to do with it. :D
Diffs often get forgotten about when it comes to oil changes,not unusal to have them go at that mileage (but they can last longer).
80 series dont usually rust too often, more so with a caring owner
Ask if you can see a cold start,meaning that it hasnt been started since the day before.
If it has good compression and
fuel system,it should only have a second or two of greyish smoke .
It should start almost immediately and run smooth.
At this age the Denso
fuel pumps begin to die. Ask if any work that has been done.
Pumps and injectors rebuilds can easily hit $2000+ for a 1HZ
Usual
sign is they lose power ,when warm at high speed as the pump expands and loses pressure.
It has a timing belt that needs changing at 100000 klm intervals.Its cheap and easy,but it has to be done
642242
