DAST disc error
Submitted: Friday, Jul 17, 2009 at 14:38
Member - Nick (TAS)
Was having trouble loading maps from DAST to SD card so uninstalled DAST from laptop and when I went to reload it, it gets to 82% loaded then freezes and an error comes up"Failed to load Ini files" and then the instilation closes.I have tried this on a couple of computers and get the same result.
Question, Is this a know fault? and is there a download that will fix it? or is it a case or throw the disc away and purchase a new one.Ive had it a few years now but it does what I want.
Thanks guys
Reply By: Member - Fred B (NT) - Friday, Jul 17, 2009 at 14:49
OK, 1st question... what is DAST?
374932
Follow Up By: Member - Nick (TAS) - Friday, Jul 17, 2009 at 14:54
Discover Aus Streets & Tracks
642244
Follow Up By: Member - Fred B (NT) - Friday, Jul 17, 2009 at 15:27
If you still have proof of purchase they should help you sort it out or replace it. At least ask them, the worst that can happen is that they say no! Worth a try anyway.
642246
Reply By: vk1dx - Friday, Jul 17, 2009 at 15:34
As you said you "tried on a couple of computers", I would suggest it was the DAST S/W installation at fault.
Go back to them and ask for assistance.
374934
Reply By: That Troopy Bloke (SA) - Friday, Jul 17, 2009 at 16:41
I wondered at first if perhaps it was unsuitable for Vista, so I just installed it on my laptop. It installed fine (DAST v 1.00).
My guess is that your CD is corrupted somehow.
There are downloads on the torrent sites. You could download it and use your own CD key. I can't see any problem with the legality of that as you already have your own legal copy.
Glenn
374948
Reply By: The Explorer - Friday, Jul 17, 2009 at 19:38
1.Also make sure you use the uninstall program on the disc to remove DAST, not via control panel.....then
2. Make sure you do a FULL install when given the option during installation process.
May solve your problem..may not.
374967
Reply By: warfer69 - Friday, Jul 17, 2009 at 20:20
Hiya Nicko
DAST is only maps not software.
Not sure how your doing it,You can connect through or if you havnt got it download Mapsend Lite,also get into habit of turning off antivirus when installing software,if you know its from a trusted place,then put maps onto SD with GPS connected using Mapsource,or you can put SD in Laptop with slot and transfer,dont forget the card is serial number connected to the GPS if you know what i mean...Would try my first suggestion first...
Last thought is depending on Antivirus used it may pay to turn it off first...
374980
Follow Up By: warfer69 - Friday, Jul 17, 2009 at 20:21
***Mapsource***
Sorry problem with having both GPS'S lol,meant Mapsend..
642259
Follow Up By: The Explorer - Friday, Jul 17, 2009 at 20:42
"DAST is only maps not software. "
I think you will find Nicko is referring to V1 of DAST ...which is software and maps - came on a CD.
642260
