Tricks to starting Dometic Fridge in Camper
Submitted: Saturday, Jul 18, 2009 at 15:03
ThreadID: 70768 Views:4042 Replies:8 FollowUps:3
Hi all,
Can anyone give me some tips to start the Dometic Fridge in the Jayco on gas. Its the manual peizo type starter.
Ive had the camper for about 4 years now and always struggled getting the fridge to work on Gas. It has always started - but only after about 5 minutes of clicking away.
Any advice will be most welcome, ie put left finger in ear and stand on one leg, count to 30 seconds and ignite etc.
thanx in advance
Reply By: Gone Bush (WA) - Saturday, Jul 18, 2009 at 15:10
Sorry I can't help you on the starting thing, sounds a bit like my BBQ. Click, click, click.
However, you might find this an interesting read:
Site Link
Click on eack picture to see a larger version. Just info to be aware of.
AnswerID: 375059
Reply By: didiaust - Saturday, Jul 18, 2009 at 15:23
We always turn on the stove and light the gas and run the burner for a minute or 2. Always helps us light fridge quicker . This has worked for many vans in the past 30 years
Di
AnswerID: 375063
Follow Up By: shanegu6 - Saturday, Jul 18, 2009 at 15:47
I do the same as Di, works much better.
Shane
FollowupID: 642343
Follow Up By: Cruiser .- Saturday, Jul 18, 2009 at 16:00
We also do that and find the fridge starts after about 2 clicks.
Cruiser
FollowupID: 642346
Follow Up By: Best Off Road - Saturday, Jul 18, 2009 at 19:57
Same here,
It lets the gas line fill with gas a lot quicker by running the stove. The piddling amount of gas drawn by a fridge flame takes ages to allow enough to to run the air out of the gas line before there is enough gas to light.
Jim.
FollowupID: 642373
Reply By: kend88 - Saturday, Jul 18, 2009 at 18:13
Haven't got the instructions handy, but from memory you have to hold down one of the buttons for an extended time, something like 20 seconds, even after you see the green indicator move.
kenD
bris
AnswerID: 375080
Reply By: Dunedigger - Saturday, Jul 18, 2009 at 19:41
I have had similar problems, sometimes takes a minute of click . . . . click . . . . click... Starting the gas stove helps if the bottle has been disconnected. The gas flow must be very slow
AnswerID: 375093
Reply By: Hairs & Fysh (NSW) - Saturday, Jul 18, 2009 at 20:07
Hi kingswoodwagon,
I don't know what model your fridge is, but if it's one of the Electrolux range it will maybe similar to this.
Image Could Not Be Found
You'll be able to access it through a panel on the out side that has several screws.
In Fig 3,It is located behind a metal panel that is fixed with screws at the bottom of the flu, clean the fluted pipe with a tooth brush and methylated spirits. With the gas TURNED OFF. Wait a couple of minutes for it to dry, turn the gas back on.
While it is all apart get someone to try and start it and see if there is a spark. If there is a spark and it still does not light, wait a minute or two and try again.
Give that a try.
AnswerID: 375100
Reply By: austastar - Saturday, Jul 18, 2009 at 20:36
get access to the back of the fridge.
Remove the covers over the flame unit (bottom right).
You should be able to see the spark lead near where the flame burns.
Get someone to 'click' the lighter, you should see the spark if you are not in a brightly lit area.
If you have no spark, wait a few minutes for any gas to disperse, get your assistant to hold in the cold start button and light the flame with a match.
Keep holding in the cold start button for about 8 seconds, there is a sensor in the flame path that holds a safety cutout valve open if it is not warm enough.
If that doesn't work, (and you did have the gas on) you may have a blocked jet.
Diisconnect the pipe connection at the bottom of the flame burner, and inside the connection you will find a small object about the size of a watch battery.
This is a flow control jet, and it could be blocked.
The hole is VERY fine and is EASILY damaged.
Try and blow it clean if you can. I could never find a needle fine enough to go near it with, even a primus stove pricker was too big.
The only wire I could fit in it was from a fine flyscreen. Some fine copper stranded electric flex may provide a wire suitable to clear the dust or what ever crud that has lodged in there.
Put it all back together and test.
It should burn with a nice blue flame, and flare up if the cold start button is pressed.
AnswerID: 375105
Reply By: dieseltojo - Sunday, Jul 19, 2009 at 10:54
Hi kingswoodwagon, All above is good asvise.
These things can be temperamental by nature of their design.the vent at the outside is level with the flame area to induce draft and get the hot air to flow up and out of the rear of the unit to get rid of hot air.Some times the slightest breeze causes the pilot flame to waft and not create the correct air mix to cause flame.
It is a good idea to ,while holding down the pilot button ,press the ignite button quickly at least four to five time as this may better ignite the gas.I have owned a lot of these units and find that the will light the firs time or the 8th time depending on their mood.
Regards Paul.
AnswerID: 375154
Reply By: kingswoodwagon - Sunday, Jul 19, 2009 at 15:27
Thanx for all your replies,
I've cleaned the flute with metho, checked the jet is clear and its starting in around 8 clicks now from cold. Thats a big improvement.
Running the stove first looks like a common practice, but I removed my stove a few years ago :)
Thanx again
AnswerID: 375196
