RA7 Diesel Fuel Bleeding
Submitted: Monday, Jul 20, 2009 at 14:45
ThreadID: 70834 Views:7439 Replies:7 FollowUps:2
Yes I ran out of fuel! 1. How do I bleed the fuel on my RA7 Diesel. Have bled the filter housing and followed the owners manual. IE key on 15secs of 10 secs repeat 5 times. Common rail set up looks a bit confusing. No luck.
2. Where do I get a good workshop manual Engine and chassis?
Reply By: Member - Tony & Julie (FNQ) - Monday, Jul 20, 2009 at 16:00
I always wondered how hard that would be :-). Glad it was not me :-)
So I will watch your post, just in case I forget about the fuel gauge and miss the warning light. Cheers Tony
AnswerID: 375394
Follow Up By: warfer69 - Tuesday, Jul 21, 2009 at 15:05
***So I will watch your post, just in case I forget about the fuel gauge and miss the warning light. Cheers Tony***
Theres not a slight hint of sarcasm there tony lmao...I always refill at quarter empty mark in the city..Occasionally its a suprise to see a quick flash of the yellow light ( roundabout's etc)..When your out in the bush with a jerry and tanami pump its not a choir to fill up...
FollowupID: 642856
Follow Up By: Member - Tony & Julie (FNQ) - Tuesday, Jul 21, 2009 at 18:07
warfer69 - I actually did not mean it that way, but when you read it it was full on sarcasm I must say :-).
My warning light comes on when I still have 20 ltrs left in the tank and thus I can still do another 150ks with ease. But I will never say I will not run out of fuel, because I may have in the past.
Looks like no quick fix for this model though. Cheers Tony
FollowupID: 642876
Reply By: Member - John D, Wandong (Vic) - Monday, Jul 20, 2009 at 18:50
Hi Psax, my mechanic had a similar problem when changing the fuel filter on my RA 2004 TD, had to disconnect the fuel line at the manual hand pump location & do a lot of line bleeding using the hand pump, but finally got it going.
Take a look at this post...some useful ideas here...Post # 24489
Good luck, regards
AnswerID: 375416
Reply By: Drew Peacock (W.A) - Monday, Jul 20, 2009 at 19:03
I have a RA6 TD Rodeo and have run out of fuel a couple of times.
Always managed to get it started using the hand pump on the filter.
I have the Holden workshop manual on our RA6 and there is nothing in it to do with bleeding the fuel system.
cheers Drew
AnswerID: 375419
Reply By: Haza - Monday, Jul 20, 2009 at 19:34
I got a earlier rodeo, a few times I have ran out of fuel I'd worked the pump for 1-2 mins and then try and start if not repeat. But once my fuel got waxed after a cold night and Roadside Assist came out and diconnected the return fuel line form the injector pump. Then he hand pumped it till it become came good.
On the number of times I've ran out I now do the above.
AnswerID: 375424
Reply By: warfer69 - Tuesday, Jul 21, 2009 at 15:10
I think the issue your having has to do with the common rail side of things...Earlier models have no issues..I topped the brother in laws Rodeo up one day with unleaded..Soon as i realized i did not turn the key..He only had it for about a year from new...We towed it to his place around the corner,pulled the tank out,refilled it with diesel and bingo..
AnswerID: 375533
Reply By: John Davies - Tuesday, Jul 21, 2009 at 16:41
Try removing the fuel filter and filling up as much as you can then reinstall.
Then start engine as per your method.
I own a new common rail Defender which has no method to self prime but I am led to believe this should work.
John D
AnswerID: 375542
Reply By: The Fox - Wednesday, Jul 22, 2009 at 13:55
Don't know about the RA7, but will share what happens with my F250 4.2 diesel.
No bleed system is fitted.
My system is:
1. remove the fuel line into the filter, and crank till i see fuel coming out that hose. Pressurizing the fuel tank gently with air helps here and on the following steps.
2. refit the fuel-in line to the filter, remove the fuel-out line from the filter.
3. crank till you see fuel flowing thru the filter. re fit the fuel-out line of the filter.
If there is air in the lines to the injectors, the injectors won't "pop" to release that air. The air just pressurizes.
4. crack at least 4 of the 6 fuel pipes to the injectors - just loosen the fuel pipe at the injector, don't remove.
5. crank till you see spurts of fuel from the loosened connection.
6. nip up the pipes.
Should start straight away.
Trevor
AnswerID: 375660
