Oziexplorer question.
Submitted: Monday, Jul 20, 2009 at 19:15
Member - Mfewster(SA)
Having received lots of advice from everyone I've done it. Got an Acer Aspire. Got maps. Got Oziexplorer. Waiting on a GPS mouse. But I can't figure out the following. I want to mark in a track that I will be doing in the Simpson later this year. When I go to the track making button, I seem to need to make a track by clicking lots of little points on the map that it will then join up to make a track line. This seems crazy. Isn't there just a way a can use the mouse to draw in the track I want? it's ok for straight stretches but coing around lots of little curves takes far too long to do all the little clicks. This can't be correct. Can it? What am I missing? Can't find this in any tutorial.
Reply By: Member - Tony S (WA) - Monday, Jul 20, 2009 at 19:26
Hi Mfewster,
To get a straight answer I think you should email Ozi direct
Tony
375421
Reply By: Travelling Pixie - Monday, Jul 20, 2009 at 19:28
it's all just points joined by straight lines to OE. does it matter if your track has chords around a bend? if they are too close by the time you see your next waypoint due you will be past it.
375422
Follow Up By: Member - Mfewster(SA) - Monday, Jul 20, 2009 at 19:44
That is going to involve an awful lot of clicking. I thought I would just be able to draw a line on the map using the mouse with the "select" button pressed, like I would draw a curving or straight line on a graphics program. If you can't do this, it seems to be an incredible oversight in the program.
642699
Reply By: Zebra400 - Tuesday, Jul 21, 2009 at 05:01
Sitting down and creating your own tracks is time consuming. However another option is to ask if anyone has a track for where you want to go. It will probably be an actual recorded track of the route you plan to take.
The advantage of a recorded track is that it can give you details about the time it takes to travel sections of the route. I use a lot of old recorded tracks to plan new trips. I can wrok out how far I want to travel in a day and where to stop for breaks.
BTW, there are some programs that allow you to move the mouse like you say. I think you will find that it isn't that easy to get track to be exactly where you want it with the mosue.
Ozi does allow you you create a track and then to go back and move the track points if they are in the wrong place. you can even add in more track points, if you feel you want a more accurate track to reflect the bends.
BTW, the pick track in the pic below is a previously recorded track for the QAA line from
Birdsville too
Poeppel Corner.
Image Could Not Be Found
375479
Follow Up By: Member - Mfewster(SA) - Tuesday, Jul 21, 2009 at 08:54
Many thanks for that Zebra. Another member is also helping on the messages page so I wont hassle you both with the same questions, unless he strikes a snag. What is the mouse program you referred to. I would have thought it would be easy to just put the map on max magnification, select the line drawing option and trace out the line wanted with either a mouse or graphic pad pen. I regularly trace out lines in Photo programs and seem to be able to do it quickly and accurately??
642806
Reply By: HGMonaro - Tuesday, Jul 21, 2009 at 10:05
Maybe you have different expectations than the programs functionality.
I haven't used tracks/
routes as I mostly use Ozi as a trip logger but maybe you should just plot significant waypoints.
Places you need to turn or want to stop. For turn by turn navigation, I don't think it's the right tool, you should be using a 'navigator' style device/program. I have used waypoints for
places to stop and it worked fine.
Cheers, Nige
375497
Reply By: MrBitchi (QLD) - Tuesday, Jul 21, 2009 at 10:16
There's a utility available from Ozi called "GmapToGPX"
This allows you to create a route using google maps/get directions which you save to a GPX file and then import to Ozi. This works fine for any track you can create in google maps.
Not too good where there are no roads but works
well for most tracks. It's a simple addon for firefox.
Ozi itself is hopeless at creating
routes..
375499
Reply By: bgreeni - Tuesday, Jul 21, 2009 at 10:48
I think you are confusing two different parts of OziE.
Routes and Tracks.
For planning purposes you use
ROUTES.
A Route is created by joining a series of Waypoints with straight lines. You can make these as close or as far apart as you wish. When travelling along the route you can use the various functions to tell you how long to get to the next way point, distance to go etc......
A TRACK is normally created when you drive along a route. It will consist of many points and is created by the readings taken by the GPS.
375505
Follow Up By: Member - Mfewster(SA) - Tuesday, Jul 21, 2009 at 12:19
Brilliant. That's the thing I hadn't been getting. Many thanks bgreeni
642830
Follow Up By: Member - Mfewster(SA) - Tuesday, Jul 21, 2009 at 21:51
bgreeni
Ive just tried to make a route and it doesn't seem to work. I went into the route editor and then tried to left click to add waypoints. Should this leave a mark/symbol on the map where I click it? I didn't get anything. EWhat do I need to do to then draw a line joining the points? The editor is either not working or, more likely, I am doing something wrong.
642908
Follow Up By: bgreeni - Tuesday, Jul 21, 2009 at 22:37
The steps are
1. Place way points on the map - to do this click 0n the waypoint button at the top of ozi (on my setup it is the 4 th button from the right - a small yellow square with a "1" inside) and then left click on the map where you want to place waypoints.
2. Bring up the route editor and click the "Properties button" - This will open the properties window.
3, Hold down the shift key and click on each waypoint in the left column of the properties window to highlight the waypoints you want in your route. (You can also just click on "Select all" to select all the way points)
4.Click on "Add"
5. Click on OK
Your route should now show up on your map (Make sure the "Show" button is selected on the top of the route editor window)
You now have a route. If you want to save it you need to save both the way points and the route using the "File" "Save to File" "Save waypoints to file" and "Save Route to File"
I hope this is clear There are lots of other things you can do in the properties window such as change the order of waypoints
642915
Follow Up By: Zebra400 - Wednesday, Jul 22, 2009 at 04:33
Even easier, is to create all of your waypoints, then go into the route editor and click on the 'Add Wp" icon in the top left hand corner. Now go back to your map and then just click on each waypoint in the order of your trip and hey presto it creates the new route for you.
BTW, this will turn off the Waypoint button. If you want to add more waypoints you will need to click on the 'Add Wp' button again to de-activate it, then you can add more waypoints.
642929
Follow Up By: Zebra400 - Wednesday, Jul 22, 2009 at 04:37
I use tracks for navigating. I prefer them to
routes for 4WDing. I prefer to follow a track I have created. I dont find it too much work and it makes life much easier when travelling in the Victorian high country so we stay on the right track.
Also by using previously travelled tracks, i can see how long it took us to complete a section we did last time. The brings down the stress levels as we know approximately when we should get to our destination.
642930
