Solar Regulator
Submitted: Tuesday, Jul 21, 2009 at 16:15
ThreadID: 70858 Views:3238 Replies:3 FollowUps:5
We have just bought a camper trailer thats fitted with a Oroca 20+, what we assume to be a regulator or flow meter for a solar unit.
My questions are -
1. We're considering buying a folding solar panel. We need to charge batteries (2 deep cycle) and run a fridge, lights and maybe a TV. What size would you recommend?
2. Is the Oroca a regulator, ie do I buy a "kit" or just a panel? It appears I have an Anderson plug to connect the panel to the system. Please excuse my ignorance - I know nothing!!
Reply By: Maîneÿ . . .- Tuesday, Jul 21, 2009 at 17:09
Alison,
I know nothing too, how about a few pictures, or more info about the Oroca ??
Basically you need to be able to replace in about 8 hours, what you remove from the battery in 24 hours.
Maîneÿ . . .
AnswerID: 375549
Reply By: Lex M (Brisbane) - Tuesday, Jul 21, 2009 at 17:13
Cant find a Oroca regulator.
You haven't misread a stylised Steca logo have you?
Image Could Not Be Found
AnswerID: 375551
Follow Up By: Maîneÿ . . .- Tuesday, Jul 21, 2009 at 21:26
Lex,
I don't believe so :-)
Maîneÿ . . .
FollowupID: 642906
Follow Up By: Lex M (Brisbane) - Tuesday, Jul 21, 2009 at 22:52
You had a lokk have you Maîneÿ. :-)
FollowupID: 642917
Follow Up By: Lex M (Brisbane) - Tuesday, Jul 21, 2009 at 22:53
try again.
You had a look have you Maîneÿ. :-)
FollowupID: 642918
Follow Up By: Maîneÿ . . .- Tuesday, Jul 21, 2009 at 23:00
Lex,
Unless I've also stuffed up, like you did, I've used the Steca serch engine and got the following result, yes direct from the Steca website:
No search result for "Oroca"
No matches found.
Change the spelling or try a synonym:
So if you think you know what it is just place the link here:
Maîneÿ . . .
FollowupID: 642919
Follow Up By: Lex M (Brisbane) - Tuesday, Jul 21, 2009 at 23:09
Maîneÿ I tried many search engines and could find no reference to any "Oroca" device.
My mention of Steca was an exercise in lateral thinking. If the device was in a inaccesible position or the marking was damaged I thought it possible that it could have been a Steca. The person is obviously not experienced with such devices. Have you any better ideas?
Excuse me for trying to help!
(By the way I would have used the spell checker but at the moment it comes up with a server error when invoked.)
FollowupID: 642920
Reply By: Mandrake - Tuesday, Jul 21, 2009 at 20:08
May I suggest my Solar Power Calculator in the members fileswap area -
It will at least let you know - approx - how many and what size panels
you require ..
Its fairly easy to fill in any problems send me a PM
Rgds
Steve
AnswerID: 375573
