Patrol y60 4.2 Diesel Turbo 1996
Submitted: Tuesday, Jul 21, 2009 at 18:48
Footwall
H folks. My question is did Nissan sell this model in Australia with factory fitted turbo? If so is there any service manuals which detail the turbo and also the wiring diagrams for that year? Many thanks.
Reply By: Luke SA - Tuesday, Jul 21, 2009 at 19:13
No they didn't. The first Nissan 4.2 turbo was the GU in 1999.
Cheers Luke
375564
Reply By: Madfisher - Tuesday, Jul 21, 2009 at 19:14
Sorry, while the motor was designed to be turboed, Nissan never did sell the turbo version in Australia. Shame
Cheers Pete
375565
Follow Up By: Footwall - Tuesday, Jul 21, 2009 at 19:44
Thanks guys. My truck is a Safari and Im having no luck finding a repair manual. Not even a Japanese version! If anyone has a suggestion I would be gratefull. Cheers
642889
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 21, 2009 at 19:51
I wouldn't think there would be too many differences between models. IE: you should be able to utilise a Gregorys or Haynes workshop manual from the TD42 Patrol. The only thing that wouldn't be covered would be the turbo; I could be wrong I spose.
Roachie
642891
Follow Up By: Footwall - Tuesday, Jul 21, 2009 at 20:22
Thanks Roachie. Yes I have the Gregorys up to 93 year. As you say no turbo stuff and the wiring is somewhat different. Is there much difference in the first Y61 model? Cheers Pat.
642897
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 21, 2009 at 20:36
I have a Gregorys (I think it is) for the Y61 so if you have any specific questions, fire away and I'll see if I can answer them.......
Roachie
642899
Follow Up By: Member - Roachie (SA) - Tuesday, Jul 21, 2009 at 20:37
Sorry, I meant to add that you would be
well advised to get onto the Patrol4x4.com
forum too....What the blokes on there don't know, isn't worth knowing.....
Roachie
642900
Follow Up By: Footwall - Wednesday, Jul 22, 2009 at 09:22
Ok. Thanks. Does the manual discuss the turbo and how to adjust and measure boost etc. Also my Safari has a sensor on the right side of radiator near the top. What is it?? I suspect a coolant level indicator but if so it is not working ! Thanks for any comments. Cheers Pat
642954
Follow Up By: Trevor R (QLD) - Wednesday, Jul 22, 2009 at 19:45
Footwall,
Could that sensor be an air-con cut-out sensor to cut the a/c when things get hot under the collar? The GU's have them but are down the bottom of the radiator if I remember right.
Cheers Trevor.
643038
