CPAP, Invertors & generators etc
Submitted: Thursday, Jul 23, 2009 at 10:49
wato35
I have a Hilux with a duel battery system and I run a CPAP and 40L Engel. Usually only get 1 night out of the battery for the CPAP, but the Engel will run another day. What size/brand genny do I need to regharge the 2nd battery daily and what price range are we talking?
I run an invertor for the CPAP that I have extended the length of the wire as they only give you 2mtrs, it now about 6 mtrs long. I used the same size wire, should I have used bigger wire?
Reply By: Member - Troll 81 (QLD) - Thursday, Jul 23, 2009 at 11:11
I don't know much about CPAP so I did a little google and found this good informative site
CPAP and Battery Power
How big is your second battery?
I use a Honda 1KVA gennie with a 3 stage charger
375811
Follow Up By: wato35 - Thursday, Jul 23, 2009 at 11:29
its a deep cycle battery, not sure to actual capacity. Actual size is about that of a normal crank battery. Currently I am 4000k's from my vehicle.
Wato
643139
Follow Up By: Maîneÿ . . .- Thursday, Jul 23, 2009 at 12:16
probably would be 80 ah minimum
Maîneÿ . . .
643145
Reply By: dbish - Thursday, Jul 23, 2009 at 11:15
Its beter to keep the 12V lead to the battery as short as possible. The 240V lead doesnt mater how long it is with in reason.
375812
Follow Up By: wato35 - Thursday, Jul 23, 2009 at 11:31
I have it at 6mtrs as I cannot always get the truck near to the camper. Should I put thicker wire on it?
643140
. . . yes
Maîneÿ . . .
643146
Follow Up By: Lex M (Brisbane) - Thursday, Jul 23, 2009 at 14:22
Depends how thick it is now.
643161
Reply By: Mandrake - Thursday, Jul 23, 2009 at 11:56
Do you need the generator or would the same amount of money spent on solar panels be better ?
You could have a look at my
Solar Power Calc and see if it is economic or not ..
Its in the fileswap under Calculators etc...
Steve
375818
Reply By: Maîneÿ . . .- Thursday, Jul 23, 2009 at 12:27
to run a small fridge direct and a cpap machine via an inverter, you need to replace what you use "obviously" so just figure out the current draw of both items is for a 24 hour period, then you need to be able to replace that in just 8 hours of sunlight if you use normal solar panels.
Maîneÿ . . .
375819
Reply By: Mitch - Thursday, Jul 23, 2009 at 15:33
Wato35 I run a 3rd battery for my CPAP machine (and hydrator) and
camp lights. It All 3 are 100 amp hours and are interchangeable. Used 6 BS sized wire with an Anderson Plug connection. Have just returned from 10 weeks away up north, sometimes had 2 or 3 days in
camp without electrical dramas. 2nd battery runs the Autofridge and the 1st battery starts the 80 series TD.
Mitch
375833
Follow Up By: Mitch - Thursday, Jul 23, 2009 at 15:40
PS I use a 150 watt Power Inverter with the 3rd battery for tyhe past 4 years without trouble.
643166
