Water Pump gone in the Paj,how much to fix?
Submitted: Thursday, Jul 23, 2009 at 20:19
ThreadID: 70923 Views:2681 Replies:3 FollowUps:2
Well after a great trip in the last 2 weeks,we got back last Thursday and the clean up began,on Sunday i degreased the motor and the under body i moved the Paj back on to the lawn,no noise Then on monday when i started it up i got this whinding noise from the front of the motor,took it to the machanic yep water pump crapped it's self i have lost a bowl full of coolant in a 100 ks,didn't get to ask machanic how much to fix as i was running late for work,and allso should i keep driving it to work{40ks there and back}.any advice would be good. thanks GD
Reply By: Roughasguts - Thursday, Jul 23, 2009 at 20:26
I got an NJ Paj. water pump and timing belt was done at the same time cause it's not much more work to replace the belt as well.
$360.00 including parts which I bought seperately! then rang lubemobile for a labour charge only. Pretty cheap huh and didn't have to do it me self! drank Beer instead.
Cheers.
AnswerID: 375889
Follow Up By: Member - GREENDOG - Thursday, Jul 23, 2009 at 21:23
Is that all it cost i thought it would be more,do u know how much the parts were.cheer's GD
FollowupID: 643240
Reply By: Roughasguts - Thursday, Jul 23, 2009 at 21:34
I think I got the parts water pump and timing belt for $140.00
Try Bursons, Repco, and places like that.
I was going to do it my self but rang Lubemobile for a labour quote and I just couldn't pass it up. I hated doing belts in East west motors.
If you go to a place like Mitsubishi well that's going to cost a grand easy with timing belt.
Good luck
AnswerID: 375909
Follow Up By: Member - GREENDOG - Thursday, Jul 23, 2009 at 21:46
ok mate thanks
FollowupID: 643247
Reply By: Ron173 - Friday, Jul 24, 2009 at 11:47
Mate,
DO NOT drive it, if that lets go you will do serious damage.
My mrs paj pump sh#t itself on a hill, overheated so fast, completely cooked the motor, heads stuffed. alloy heads not worth maching, plus age of engine generally, we ended up fitting a new engine, 3.0ltr v6 petrol, cost us 5000, that was drive away.
So if you continue to drive it your asking for trouble, accept the inconvenience meantime, it will pay off.
Rgds
Ron
AnswerID: 375986
