FITTING WARN XD9000 WINCH TO HILUX
Submitted: Thursday, Jul 23, 2009 at 20:35
ThreadID: 70924 Views:10746 Replies:3 FollowUps:1
Hi, We are wanting to fit a Warn XD 9000 winch onto our 2007 4X4 hilux Dualcab. Can anyone tell us if it is possible?
We have the genuine Toyota breaker bullbar and genuine winch mounting plate. Will we need modifications to the bar or plate or will it simply bolt on. Have already got the auxillary battery fitted, just not sure if the winch will fit!
Any thoughts/ideas appreciated, thanks.
PaulnKattie.
Reply By: Maîneÿ . . .- Thursday, Jul 23, 2009 at 22:36
Run winch from Cranking batteryImage Could Not Be FoundMaîneÿ . . .
AnswerID: 375922
Reply By: Member - Stuart P (WA) - Friday, Jul 24, 2009 at 08:33
it should, there is a strengthener in in the bar that may need fitting, the winch will fit straight in bolting up to the holes in the bar where the nuber plate is. the controller will mount in the middle of the bar between spotlights
AnswerID: 375958
Follow Up By: paulnkattie - Friday, Jul 24, 2009 at 16:26
no worries, thanks for the help
FollowupID: 643391
Reply By: Member - Alan John C (WA) - Saturday, Jul 25, 2009 at 19:19
Hi Paulnkattie, I fitted xd9000 to our lux and it works very well it is advisable to run an exrta earth strap to chasis this helps reduce chance of over heating, my only concern is the bar you wish to fit it to not renowned for their strength that is your call go steel ARB if you can and you will guarentee it all to fit and as previously sugested run off crank battery and check with insurance company you may need an isolation switch regards Alan.
AnswerID: 376198
