Poly Water Tank in a Space Cab
Submitted: Tuesday, Jul 28, 2009 at 00:05
kwk56pt
I was about to fit a 85 litre poly
water tank 1200 long X 200 high by 400 wide into the cab of a Rodeo Space Cab. I realise the construction of these tanks does not allow for baffles and now I am wondering about the noise from
water sloshing about in a
tank when its not full.
I had planned to put a false floor / shelf over this. The alternative is 12 X 5 litre willow containers tied down in pairs which would fit neatly under this shelf instead of the
tank. Any comment on the likely
water noise from the poly
tank or the practicality of the alternative willow containers idea. ...Thanks Peter
Reply By: Member - greg S (QLD) - Tuesday, Jul 28, 2009 at 08:46
Peter,
I cannot comment about the
water tank in the cab as I don't have one,
But we have a number of the 5L and a couple of 10L
water containers, not too sure if they are willow or not but they have red screw cap lids and come from BCF. I had them in the camper, so cannot tell you about the sloshing noises but they made it alot easier to handle and pack. I put marine carpet squares in between them all to stop rubbing, and a big piece over the top so I could pack other stuff on top of the containers. They weren't tied in, but I packed our gear around them so they didn't move. My wife and daughter can carry them with ease, not like the 20L ones we also have.
376536
Reply By: Member - Phil G (SA) - Tuesday, Jul 28, 2009 at 08:55
I used to store 20l jerry cans of
water and diesel in a steel cage behind the front seats on a Prado. Yep you could hear the
water sloshing a bit, but it didn't bother me. Only sloshes when your vehicle is lurching around.
Big issue is to have the
tank or jerry cans
well secured and tied down to the floor. Don't want them to go flying in a prang.
I used to access
water with a syphon hose that goes through the lid of the container (need a small breather too), with a 2-way tap on the end. The other advantage of jerries is that you don't lose all your
water if it springs a leak and you can separate good
water from dodgy
water.
376539
Reply By: Atta Boy Luther - Tuesday, Jul 28, 2009 at 09:24
atlas tanks Checkout page 10 , internal moulded baffle .
376544
Follow Up By: kwk56pt - Thursday, Jul 30, 2009 at 00:22
Checked out atlas, good range of tanks, price ok freight reasonable. The size I need does not have a baffell but as I plan to put a false floor over it I think I will put some of that jute based noise dampening underlay over the
tank to reduce some of the noise.
Thanks for the information
644173
Reply By: Member - Troll 81 (QLD) - Tuesday, Jul 28, 2009 at 09:49
Hey Peter,
I have a 80l
water bladder behind the front seats and it does slosh a little bit but not enough to put me off
376546
Reply By: WYSIWYG (Bundaberg Qld) - Tuesday, Jul 28, 2009 at 18:14
Hi Peter
We have a 50litre poly
water tank in the back of the cruiser. The sloshing noise is noticeable when travelling slowly but once up to road travelling speed we can't really hear it over the normal road and engine sounds. However, until a couple of days ago we've been completely baffled by an intermittent noise that sounded like it was coming from a rear wheel or somewhere in the vicinity of the the rear cargo area, but it only occurred when turning to the right. Finally tracked it down and it turned out to be the air coming out of the non-return valve on top of the
tank. The
water tank was nearly full at the time and the noise was caused by the
water sloshing across and forcing the air out of the valve. Big relief when we figured out what it was....lol.
376583
