Water Tank cleaning in my C/T ..
Submitted: Wednesday, Jul 29, 2009 at 11:00
ThreadID: 71052 Views:3599 Replies:3 FollowUps:3
Last thread today ---
My PVC water tank has some water in it from last trip - 3 months ago ..not full !
I've read the threads on using Baking Soda and other things to clean and flush ..
The water tastes OK - Would it still be advisable to clean , drain and flush before
heading off ?
Steve
Reply By: vk1dx - Wednesday, Jul 29, 2009 at 11:25
Yes
At least drain and flush. It won't hurt. If you have an excellent memory like mine (Ha) you may never know where the water that is in the tank came from. Don't want "Bali tummy" now do you.
We always flush out all drinking water containers the night before a trip as a must do.
What do the makers say about cleaning? Do they mention anything special?
Just my two bobs worth.
AnswerID: 376647
Reply By: Member - Andrew (QLD) - Wednesday, Jul 29, 2009 at 11:25
No harm in doing it Steve. ;)
A good flush using bicarb (to loosen any buildup) before your trip is cheap and gives your water a good start. Dependant on locations, reticulated water has residual chlorine in it to kill any organics/nasties so should be of no concern.Water may become a problem when not used and left stagnant.
Enjoy your trip :(
Andrew
AnswerID: 376648
Follow Up By: Member - Crazy Dog (QLD) - Wednesday, Jul 29, 2009 at 13:19
Following on I had the dreaded TAINT problem and found an easy way to fix it.
1st drained the tank and then refilled to brim and added about 150ml of pool chlorine (bleach). Let it stand for a week then emptied the tank and flushed about 3 times. Then I refilled and added BICARB (1/2 packet) and let it sit for a few days then drained again.
Left it dry until I need to go camping and did a quick flush before refilling for the trip.
The water was pristine this time and NO CHEMICAL OR TAINT PROBLEMS....so I now empty my tank dry when I get back home and never had a problem since. Also use potable water hose and NOT THE GARDEN HOSE...
Grrr!!!
FollowupID: 644069
Reply By: Member - Mal W (NSW) - Wednesday, Jul 29, 2009 at 14:27
One plastic tank supplier suggests using Milton, the baby bottle/teat cleaner. You can get it in liquid or easier to carry tablets.
AnswerID: 376666
Follow Up By: Member - Boo Boo (NSW) - Wednesday, Jul 29, 2009 at 18:03
Mal
We recently bought a camper trailer with a 65 ltr tank. i was going to use nappysan to clean the tank, my wife was not impress. She agrees with you. I used Milton and we have used the tank twice and have had no problems.
FollowupID: 644097
Follow Up By: Member - Sigmund (VIC) - Thursday, Jul 30, 2009 at 06:15
Nappysan is just bleach if I can remember from my nappy washing days.
Should be fine used well diluted but a lot of rinsing after will be needed.
Re Miltons, someone posted here that it has to be in contact with all the tank surfaces to work properly.
FollowupID: 644180
