Thursday, Jul 30, 2009 at 13:24
There are some very basic points that most everybody apperars to be missing in the VSI 50 rules.
It is not about lifts or drops for vehicles ... its about what the govt intends to class as "modifications" to a vehicles
suspension ... and the govt processes intended to be imposed on the motoring oublic for carrying them out.
NSW govt wishes to impose a fixed "vehicle height" on your vehicle ... whether it be
sedan, ute, sports car, 4wd, a classic rebuild, whatever.
This height would be measured from the wheel centre to the bottom of the wheelarch on your vehicle.
Any changes to that "vehicle height" would be deemed a "modification" requiring approvals / inspection / certification.
So if one replaces a steel bullbar with an aluminium one and the weight factor causes a change in the height the govt has specified for your vehicle ... It has been "modified" and is "illegal" until inspected and the veh specs adjusted on the records of your vehicle according to the wording of VSI 50.
REMEMBER ... The wording of VSI 50 is ...
"Apart from minor wheel changes allowed in VSI No. 9 Guidelines for alternative
wheels and tyres, it establishes that any raising or lowering of a vehicle from its original ride height is a major modification, and it limits the change in ride height of a vehicle intended to be used on roads or road related areas to ± 50 mm.
plus or minus 50mm ..... thats not a 2" lift kit ... thats any variation from your vehicles recorded trim height from 1mm to 50mm ... from its "original ride height".
A major modification ..... pfffft ........ How many NSW drivers really want to to add a $900 + inspection fee to the cost of a new bullbar ... or winch ... or rear tyre carrier/towbar changeover ... or removing auxilliary fuel tanks etc ... because of a 5mm or whatever variation in ride / trim height ????
How many interstate drivers would like to see the NSW rules adopted in their state ... just because NSW did it ????
Some points that I think should be presented now that there is a consultation process about to occur are.
1/..VSI 50 needs to dropped completely.
2/..
Suspension adjustments of up to 50mm and within the one third bumpstop travel - should be left as a non approval circumstance.
3/..Changes to
suspension over the one third bumpstop travel and / or requiring vehicle structural changes, need to CONTINUE to be requiring approval / inspection / certification.
4/..Better enforecemnet of existing rules that deal with illegally modified vehicles - need to be demanded.
376811
