Colorado problem
Submitted: Thursday, Jul 30, 2009 at 14:42
ThreadID: 71084 Views:5409 Replies:14 FollowUps:15
HUge........Problem
got my car back on friday the other week drove it all tis week and noticed alot of my engine oil gone.... and some oil under the car took it to holden and they said they would have to have it for the night..got my car back they said the oil under the car was left ova from when they did the oil gutter and block ring.
But now when i start my car heaps of oil is spurting out of the exhust and heaps of soot and smoke is my car forked?? it used around 7L oil when i took it in they said they changed the oil to a thicker oil but there is still heaps coming out ?? any help
Reply By: sweetwill - Thursday, Jul 30, 2009 at 16:15
hi shaneo86
just check the drain plug is in cheers bill.
AnswerID: 376823
Reply By: Malleerv - Thursday, Jul 30, 2009 at 16:37
"But now when i start my car heaps of oil is spurting out of the exhust and heaps of soot and smoke is my car forked??"
Sounds like turbo seal or broken rings.
"when i took it in they said they changed the oil to a thicker oil but there is still heaps coming out ??"
That sounds very dodgy.
AnswerID: 376825
Reply By: Member - Cozzie Toodyay (WA) - Thursday, Jul 30, 2009 at 16:45
Stick a realy big lemon on the roof and park it out the front of the Holden dealers.
AnswerID: 376827
Reply By: Member - Tony & Julie (FNQ) - Thursday, Jul 30, 2009 at 16:51
Yep sounds like you killed it - Cheers Tony
AnswerID: 376828
Reply By: Member - Alan John C (WA) - Thursday, Jul 30, 2009 at 17:08
Shane, surely being a Colarado it is under warranty and thicker oil won't fix the problem. Take the filler cap off and place your hand over it and run your vehicle see if you have oil on your hand if so you will find rings the problem if no oil then you have turbo problem as suggested by other members don't let them dictate to you it sounds as they are trying to pass the buck and if continues let us know who dealer is so all members can steer clear of them cheers alan.
AnswerID: 376835
Reply By: Sir Kev & Darkie - Thursday, Jul 30, 2009 at 17:41
I'd go and buy some Tequlia and salt and go drink it with you lemon ;)
I would definately be pushing for a new vehicle.
Cheers Kev
Russell Coight:
AnswerID: 376841
Follow Up By: Member - Tony & Julie (FNQ) - Thursday, Jul 30, 2009 at 18:07
Correct me if I am wrong, but shane086 may have voided his warranty. From earlier posts I think Shane installed a modified exhaust, a rather large one. If so then it could be hard to ask for another car.
I would have the same problem if something went wrong with my running gear, having done some mods to it.
All in all he has had a bad run of luck Cheers Tony
FollowupID: 644256
Follow Up By: shaneo86 - Saturday, Aug 01, 2009 at 21:13
na... rang them it doesnt void it
FollowupID: 644515
Reply By: rocco2010 - Thursday, Jul 30, 2009 at 17:58
Gidday
Not a wind-up Colorado is it?
Rocco
AnswerID: 376844
Reply By: Member - Graham H (QLD) - Thursday, Jul 30, 2009 at 18:12
Seems very strange that it went in for a clutch and gearbox problem and comes out with a severe oil problem.
Probably they wouldnt touch anything to do with the engine oil or the turbo other than perhaps removing the shiny exhaust.
Must be more to it than what is being posted.
Lots of Luck.
AnswerID: 376847
Follow Up By: Member - Tony & Julie (FNQ) - Thursday, Jul 30, 2009 at 19:43
Be interesting to see the mechanics report :-) Cheers Tony
FollowupID: 644273
Follow Up By: shaneo86 - Thursday, Jul 30, 2009 at 20:10
allways the exhaust....wont let go of that will ya...so what i got a S/S system woppy... its my 1st 4wd i was goin to keep it for a long time "WAS" nope all that iv posted is correct.
1. 3 clutches
2. one full clutch assembley
3. slave cylinder
4. oil gutter and outer block ring
5. 2nd gear bush dry / reoiled
6. clutch adjustment
7.clutch adjustment
8.clutch adjustment
9. gears crunching / drained oil and added revised oil "thicker" started oil consumption test
10. oil coming out of the AAAAWSOME system pff.. " and it wasnt water either coming out i got it on my phone photos and video of it getting worse and put my hand near the end and was oily
FollowupID: 644282
Follow Up By: Member - Graham H (QLD) - Thursday, Jul 30, 2009 at 21:38
This post has been read by the moderation team and has been moderated due to a breach of The Personal Attacks Rule .
Forum Moderation Team
FollowupID: 644299
Reply By: Member - Axle - Thursday, Jul 30, 2009 at 20:52
Mate if its bad as you make out!, Then think about Dept of fair trading sale of goods warranty. The goods must be fit for the purpose supplied!.....Worked for me a few mths ago.
Cheers Axle.
AnswerID: 376859
Reply By: Member - AJB (VIC) - Thursday, Jul 30, 2009 at 21:20
How hard are you driving this thing? They aren't a Trophy Truck! You contributed to the original clutch failure with the bogging in sand drama, so do you redline the thing trying to keep up with the mates dunnydore? This is your 1st 4WD, none of them are unbreakable despite what you see on the advertisements. Is it your 1st manual aswell! I know, from one of the vehicles that I have now, that there are faults with modern vehicles but if yours is entirely un-driver related I'd be extremely surprised.
AnswerID: 376869
Follow Up By: landed eagle - Thursday, Jul 30, 2009 at 23:11
I agree AJB.
I've just gone from a 4.0 Ltr Falcon auto, to a 3.2 TD Triton manual. Took a couple of weeks to get the head around how to drive it, as it's my first diesel.Took a couple of kg's of lead out of the right foot and now all is good!
The advert is right. I 'love that car'.
FollowupID: 644315
Follow Up By: shaneo86 - Friday, Jul 31, 2009 at 12:38
look...first upp it isnt my fault even holden said so wen i got the first clutch done no its not my first bloody manual either i drive a iszuzu 200 at work and thats fine i drive tractors at work all fine all day everyday at work its a problem with this car ask any colorado owner from what i hear there is one up at cairns with the same problems one down south had to get a new gearbox.
i dont drive it hard at all change gears just under 2000RPM and its fine oh yea becouse getin stuck makes the clutch go it was going before then anyways duh should have asked before sayin that oh yea i go out to the drag strip all the time drag off nissan navaras all the time redline man pfff same that people that know nothing about problems like this reply to things that they dont know anything about
FollowupID: 644374
Reply By: Stu-k - Friday, Jul 31, 2009 at 08:01
Here is your answer you wont look back
AnswerID: 376910
Follow Up By: Member - Oldbaz. NSW. - Friday, Jul 31, 2009 at 10:03
Good one, Stu-k, I quite agree. Apparently Colorado clutch assemblies & front
brake assemblies werent able to be sourced from Isuzu for Colorados & some
dud gear was substituted. I believe local dealers are now fitting the original
Rodeo/Dmax gear as replacement under warranty. A young friend has had both replaced. His gearbox is rattling & has been told to drive it till it breaks & they will fit a new one from Isuzu under warranty. Cant fix it now as only option is
to repair not replace unless it sh*ts itself. I think Shane is being dudded, adding
thick oil is a copout.......oldbaz.
FollowupID: 644356
Follow Up By: Member - Tony & Julie (FNQ) - Friday, Jul 31, 2009 at 16:37
Thats no answer - Not everyone is made of dollars - Cheers tony
FollowupID: 644393
Follow Up By: Stu-k - Friday, Jul 31, 2009 at 17:22
The rich get richer the poor get poorer.....resale
FollowupID: 644398
Follow Up By: shaneo86 - Friday, Jul 31, 2009 at 20:36
see my gearbox hasnt been rite when i got my clutch done and was rite to go i hoped in my car and went to change it from 1st to reverse it wouldent go change at all... was stuck in 1st i dont know how they got it out of 1st but when they did they had to keep it for the weekend and for 2 days said it was somthing broken in the clutch so they had to pull it all apart again from then on the crunching had been getting worse and worse in the mornings feels like i got no clutch at all
FollowupID: 644424
Reply By: Member - Cozzie Toodyay (WA) - Friday, Jul 31, 2009 at 13:30
Shaneo, ya need to go hard and take no crap from the mob that you are dealing with you pay good hard earned money for these vehicles and they are trying to stooge ya mate, changing the grade of the oil is a patch job not a fix.
Hope ya get it sorted mate sh#t like that would send me into a blind rage.
AnswerID: 376986
Follow Up By: shaneo86 - Friday, Jul 31, 2009 at 18:58
yeah know like wen i told them about my gears crunching heaps and they took it for a "test drive" and couldent foult it...its crap as they have it wen it hot in the mornings or wen it been sitting all day it sounds like there is no clutch there at all somtimes...and wen i said to the sate manager so i hear your using dmax running gear "oh...umm thats correct" so why dont they frigging recall all of em it turning into a bloody navara so bloody over it
FollowupID: 644410
Follow Up By: Member - Cozzie Toodyay (WA) - Friday, Jul 31, 2009 at 21:28
Hi Shaneo86, no offence mate but is it some sort of SMS language you are using.
I am no genius but it has me stumped what you are on about sometimes, try the spell check it may not let you down.
And don't give up mate make the bastards fix your Colorado.
PS: has it got a Sports Bar and Tonneau cover? :)
FollowupID: 644428
Follow Up By: shaneo86 - Saturday, Aug 01, 2009 at 21:12
yea yea i know spelling bad and yes i use sms alot alot... joins into everything i do anyways na got rid of the tub well not really tryin to sell that swaped it for a alloy tray beta resale later on the state manager didnt like it wen i said about holden using dmax stuff now gearboxes and so on askin how i knew about it.
this morning the gearbox was clucking loud AS.. when i was driving it was stuck in between 2nd and N got it on my phone crunching on the spot
FollowupID: 644513
Reply By: Wizard1 - Friday, Jul 31, 2009 at 14:41
You have to wonder why a near new truck has had to have so much work done, oils changed, etc.
Sounds like you got one of those mythical lemons that appear every now again with some makes.
AnswerID: 377000
Reply By: Member - Amy G (SA) - Friday, Jul 31, 2009 at 17:41
Did you take it back to the dealer?
AnswerID: 377020
Follow Up By: shaneo86 - Friday, Jul 31, 2009 at 18:55
waiting all bloody day for the state mager to call me to talk about this problem...5pm i get a call look does it smell oily "hmmm yea strong as.." ok take it to the dealer "it shuts at 530" got there at 536 and all i got was hmm we will book it in for monday and then walking back to my car the forman was outside and said to him mate this shipbox is using a heap of oil "oh thats no good and rushed off"
FollowupID: 644408
