Wheel nut indicators
Submitted: Thursday, Jul 30, 2009 at 18:16
ThreadID: 71088 Views:6307 Replies:9 FollowUps:14
Gidday
I was talking to a truckie this morning after noticing yellow tags on the wheel studs. He informed me they were ‘wheel nut indicators’ which is fully explained at http://redcatindustries.com/wheelsafe.htm.
As I haven’t seen these before, I rang the company and was informed they have them for 4wd and trailers. Apparently some ARB stores stock them also.
Kim
Reply By: Member - Mark G Gulmarrad - Thursday, Jul 30, 2009 at 18:57
Kim
as much as a good idea as they are to visually see if the wheel nuts have worked loose............they are a real PITA to put back on ever time you have to change a truck tyre.
hence most of the time they live in many truck tool boxes.
AnswerID: 376852
Follow Up By: Kim and Damn Dog - Thursday, Jul 30, 2009 at 19:36
Gidday Mark
I don’t have any experience with the product as I only came across them today. The fella I was talking to seems to have built up a bit of a following in the mining industry.
Can you expand a bit on why these things are a pain to fit?
Kim
FollowupID: 644269
Follow Up By: get outmore - Thursday, Jul 30, 2009 at 19:41
there not - you just push them back on either by hand or if there tight with the brace
FollowupID: 644271
Follow Up By: Member - Mark G Gulmarrad - Thursday, Jul 30, 2009 at 19:41
Kim
its not that they are a pain to fit as such........but there are so many of the damn things that you have a full container of them to carry around to fit after the wheel has gone on. they are a bit like the chrome wheel nut covers they fit on truck wheels to make them look pretty.
i spose in the right applications they would be great things to have.
FollowupID: 644272
Reply By: viz - Thursday, Jul 30, 2009 at 19:41
Truck wheel nuts suffer from "creep" i.e. they can creep undone. You gotta check them regularly. 4WD wheel nuts do not seem to have the same problem. It would be WOFTAM I think to put them on 4WDs
viz
AnswerID: 376856
Follow Up By: BenDiD - Thursday, Jul 30, 2009 at 19:45
sorry, WOFTAM?
FollowupID: 644274
Follow Up By: get outmore - Thursday, Jul 30, 2009 at 19:46
yea im not sure id bother, its more of an OHS minesite thing - these guys will rave on how much safer it makes things but yet they dont have them on their home car to drive there wife and 4 kids around in
FollowupID: 644275
Follow Up By: viz - Thursday, Jul 30, 2009 at 19:49
This post has been read by the moderation team and has been moderated due to a breach of The Foul Language Rule .
Forum Moderation Team
FollowupID: 644277
Follow Up By: Member - Toyocrusa (NSW) - Thursday, Jul 30, 2009 at 19:49
BenDiD. Waste of time and money. Bob.
FollowupID: 644278
Follow Up By: Member - Toyocrusa (NSW) - Thursday, Jul 30, 2009 at 19:51
OOPs. That was just a WAFT.
FollowupID: 644279
Follow Up By: oldpop - Thursday, Jul 30, 2009 at 21:13
Wheel nut indicators are for steering wheel attendants
Real truck drivers use a wheel brace regularly
Oldpop
FollowupID: 644286
Follow Up By: viz - Thursday, Jul 30, 2009 at 22:13
AMEN
viz
FollowupID: 644307
Follow Up By: Member - TonBon (NSW) - Friday, Jul 31, 2009 at 09:31
Nice one oldpop, i am sure my father would agree 100%, i know i do.
FollowupID: 644340
Reply By: Member - Ian F (WA) - Thursday, Jul 30, 2009 at 20:15
G'Day,
Most mining companies have made these compulsory on all vehicles entering any mine site.
Ian
AnswerID: 376858
Reply By: pafc - Thursday, Jul 30, 2009 at 22:11
To ensure your wheel nuts don't come loose invest in a good quality torque wrench and tension the nuts to the torque value quoted in your manual.
Alex
AnswerID: 376879
Reply By: raafy - Thursday, Jul 30, 2009 at 22:56
I started fitting these indicators when I was in charge of a bus workshop looking after a fleet of 60 various types of buses. Even though the wheel nuts were tightened to the correct torque with a tension wrench, some wheel nuts still loosened (especially Volvos). They were a time saver as you only had to visually check that the indicators were lined up to know that no wheel nuts had loosened. At a cost of 33 cents each it was money well spent.
AnswerID: 376884
Follow Up By: Kim and Damn Dog - Thursday, Jul 30, 2009 at 23:40
Raafy
Interesting replies. The truckie I spoke to reckoned they where pretty good. A quick walk around the truck....
If I can find a source in Melbourne, I'll stick a set on the camper trailer. My interest was raised when I read they indicated problems with the bearings.
How they function with the wheels full of mud, remains to be seen.
Anyway, I'll give it a go considering the low cost.
Kim
FollowupID: 644318
Follow Up By: Member - Timbo - Friday, Jul 31, 2009 at 14:54
Kim, knowing that they're pitched at fleet operators, you probably get them in a small box of 10,000, or a large box of 50,000. May not be such 'low cost' then! :)
Let us know what quantities they can be ordered in (you may be able to just get a dozen freebies to 'sample')
FollowupID: 644388
Reply By: Flywest - Friday, Jul 31, 2009 at 01:04
Kinda makes a mockery of wheel balancing then - doesn't it!
AnswerID: 376895
Follow Up By: get outmore - Friday, Jul 31, 2009 at 10:36
the light weight of the plastic and the fact the are towards the centre of the wheel rather than the outer would have no noticable effect on wheel balance.
balancing can be overrated anyway Ive changed a few tyres including front ones and just used the same weights in the same spot with a different tyre and not noticed any shake
FollowupID: 644361
Reply By: Volvo driver - Friday, Jul 31, 2009 at 07:50
l work for a corporation that has one of the biggest transport fleets in oz and these nut indicators are a good idea..anyone walking past the vehicle, when parked in the yard or anywhere else can see at a glance whether you've got loose nuts... which could be a problem LOL,
they're a good idea, whether you've got one vehicle or hundreds..
AnswerID: 376909
Reply By: robertbruce - Friday, Jul 31, 2009 at 10:29
i didnt know truck wheel nuts "creep".... these items should be mandatory...
In two years of travel Ive
yet to see a truckie holding a wheel brace
had a semi wheel come off in front of me and seen the damage it can do careering up the highway
AnswerID: 376951
Reply By: Willykj - Saturday, Aug 01, 2009 at 18:22
I've used these wheel nut indicators for 2 years on my caravan. The company will supply them in lots of 10.
The reason I started using them was because my near new van lost a wheel after only having been towed for 900km. The nuts had come loose even though I had checked them with a brace 120km prior. It's a long story but it appears the problem was with the rims - the manufacturer changed all my wheels. When travelling again I was very nervous......so when I read about the indicators I bought them straight away.
As fas as I am concerned they are great - I just do a walk around each time I stop - haven't used a brace for 2 years. Great peace of mind. Have done months of van travel & the indicators stay on the nuts OK>
Willy
AnswerID: 377112
