Prado Petrol Vs Diesel
Submitted: Thursday, Jul 30, 2009 at 19:21
ThreadID: 71091 Views:9565 Replies:7 FollowUps:3
We're considering either the Prado 4L petrol or 3L TD to tow a 21ft 2000kg caravan. Has anyone had experience with either of these, which vehicle is better. Is the Prado sufficient as there is a big $ increase to the landcruiser. If there are Prado users for this size van how do you find it. What speed can you comfortably cruise at and fuel economy. Any advice appreciated
Reply By: Cruiser .- Thursday, Jul 30, 2009 at 19:43
Bruce & Janice
Our van is 23' from tow coupling to rear bumper and weights 1940kg dry.
We tow with a 2004 3L Turbo Diesel manual and generally sit on 90 - 100K/hr and get an average of about 16l/100K when towing. (Keep in mind that ours is not the new D4 engine)
Hope this helps.
Cruiser
AnswerID: 376857
Reply By: TerraFirma - Thursday, Jul 30, 2009 at 21:09
Either model will work well however the Diesel will deliver better fuel economy across the board especially when not towing. You will have no problems cruising at a safe speed, ensure your weight is balanced. The diesel will also deliver a better range so it would be my choice.
AnswerID: 376862
Reply By: Member - Toyocrusa (NSW) - Friday, Jul 31, 2009 at 06:29
Hi. I own the petrol 5 speed auto which I find fantastic for towing 2tonne. Have got up to using 20lt/100k in a head wind though. Normally around 18.I have been looking at the diesel but find them much noisier than the petrol. There will be a new model Prado by the end of the year. There has been no info on engines yet but should make for some good buys on the current model as people upgrade. Regards,Bob.
AnswerID: 376899
Reply By: ChristaJezz - Friday, Jul 31, 2009 at 08:05
G'day Bruce, Janice,
We have similar plans and had to make the same decision. We recently bought a 4.0L petrol Prado.
Things we considered :
- Purchase price : Petrol is cheaper
- Re-sale : Diesel is better
- Servicing : Petrol is cheaper (refer www.carservice.com.au)
- Range : Diesel is better
- Towing : Diesel is better
- Longevity : Diesel is better
- Fuel Availability : Diesel is better
- Economy : This is where it gets interesting
- Diesel vs petrol, diesel is cheaper
- Diesel vs LPG, gas is much, much cheaper
We went petrol because it was significantly cheaper for us. We will hang on to the car so re-sale was not an issue. We are not planning on going into the middle of no-where so range & availability weren't issues.
We had ours converted by LPGas1 in Melbourne straight after we bought it. They are one of the best and we can not recommend them highly enough. You will loose the secondary tank to fit the 68l useable gas tank. We get about 400kms out of the gas tank but it is only a few weeks old so will need to be fine tuned. No difference in performance.
Toyota do not recommend LPG conversions however many more experienced people than us have converted with no issues. Be sure you go with the latest sequential gas injection system with the added insurance of a flash lube kit.
If diesel is for you I would seriously recommend the D4D engine.
Check out pradopoint for more info from the experts.
Whatever engine, we believe the Prado is a fantastic car and we are very satisfied with our choice.
Take care,
Chris and Jezz.
AnswerID: 376911
Follow Up By: Madfisher - Friday, Jul 31, 2009 at 22:26
Longevity Diesel is better hmmm. Had a talk to the head mechanic who services our car fleet about this very question, . His reply is the better petrol motors are doing well in excess of 400000ks, but every week he has a 4 cylinder turbo diesel in his work shop that has a major problem. Most of these had less then 200000ks, and most of the problems seemed to be heads. So his reply was he reckoned that a modern petrol will outlive a highly stressed 4 cylinder itd.
Plus for the price of common rail injectors and fuel pump you could rebuild a petrol anyway.
Cheers Pete
FollowupID: 644438
Follow Up By: Davo_60 - Saturday, Aug 01, 2009 at 18:22
X2, I would back the petrol Prado to outlast the new diesel, the 4 litre petrol is a great engine and relatively simple compared with the common rail diesels. Diesels aint what they used to be with regard to reliability and the diesel fuel available is not all that good and the new diesels don't like that a hell of a lot.
Dave
FollowupID: 644476
Reply By: Wizard1 - Friday, Jul 31, 2009 at 15:11
Yes, the petrol car is always cheaper. There is a reason for that.
Yes, ULP is cheaper than diesel, but only by a smal margin nowadays.
But what most supporters of the petrol tow vehicles is the price of the fuel is out weighed by the fact you use more to cover the same distance as a diesel.
My old 2002 1KZTE 3.0 TD gets around 15 - 18 L/100 km towing a 1800 kg van. While most 4.0 Prado average much more than that. I've read figures between 18 - 22 L/100 km.
Yes, they cost a bit more in servicing (only because of the intermediate oil change), but my old girl with over 170,000 km, with cracked head towed the van from the Gold Coast to Adelaide up the Birdsville track (including doing Big Red) and back to the Gold Coast, while still cruising at 100 kph in 5th gear with the same economy as normal.
I replaced 2 Aussie petrol 6 cylinder tow cars with the diesel and would never go back
AnswerID: 377007
Follow Up By: Davo_60 - Saturday, Aug 01, 2009 at 18:25
"with cracked head" ..... The 1KZTE's have a tendency to do that unfortunately.
FollowupID: 644477
Reply By: Member - Rob - Friday, Jul 31, 2009 at 21:44
Bruce
I am just travelled throughout the Cebtral Highlands of Qld and have spoken to many Prado owners after I had a conversation with a diesel owner and quizzed him on consumption when towing his 20ft Galaxy van. He said he was averaging 18/19lt per 100km. And 9lt around town when not towing. After that I started quizzing more and his figures seem to fairly consistent. I have not spoken to any petrol owners yet. Most petrols I have seen are in Emerald (the place is lousy with them) but we were only there 1 night so I did not get to talk to anyone.
I asked the question because I am running a V8 petrol cruiser towing a 2.5 tonne van and she is sucking up the juice I can tell you. I am getting an average of 25lt per 100km towing plus a roof rack with 2 kayaks on top.
Rob
AnswerID: 377063
Reply By: Bruce & Janice - Saturday, Aug 01, 2009 at 07:59
Thanks everyone, getting some good info although I keep swaying back & forth as I read more. Toyota advised the new model Prado comes out 16th November but couldn't supply info on specs.
One further query is on how the auto compares to manual when towing, I've previously only towed with a manual but a friend towed his van over from WA in a landcruiser and swears by it although a lot more power is available.
AnswerID: 377090
