VMS gps system issue
Submitted: Friday, Jul 31, 2009 at 08:26
ThreadID: 71102 Views:2883 Replies:2 FollowUps:2
Hi all, Fitted a new vms 3000 gps system to my 06 hilux yesterday, after install i couldn't power up unit whilest vehical was off. Even tho my spare battery voltage was 12.9v... once i started my vehical the unit powers up no worries. But when i have turned off the motor and the voltage drops to about 13.5v the unit shuts down.. Has anyone else had this issue before, i wouldn't have thought it needed 14v to run the unit, if thats the case i can't even listen to the radio with the engine off.... I have a dual bat system fitted, and i have the main power supply for the unit comming off my spare battery, would this make any difference??? Any thoughts would be helpful
Reply By: Member - Wim (Qld) - Friday, Jul 31, 2009 at 09:00
Kato Kid
My VMS unit has been in for over 6 months with no hint of a problems such as yours.
Have you measured the voltage at the unit with the engine off? Maybe you have a poor connection somewhere and are dropping a couple of volts.
regards
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 376922
Reply By: The Landy - Friday, Jul 31, 2009 at 17:30
Have you hard wired in or through the cig liighter?
AnswerID: 377018
Follow Up By: Member - Graham H (QLD) - Friday, Jul 31, 2009 at 20:32
Most car units have a wire for power and a wire for power to the memory.
This normally goes to an always on source and then you wire the units on /off
switch to a switchable accessory source.
Perhaps you havent got them correctly hooked up.
Just a thought
FollowupID: 644419
Follow Up By: The Landy - Friday, Jul 31, 2009 at 22:38
Reason I ask is that VMS is a USB connection and runs off 5 volt, can't wire direct to a 12 volt system...
Not sure if that was the question...
FollowupID: 644443
