Disconnect cranking battery to charge ?
Submitted: Friday, Jul 31, 2009 at 09:26
ThreadID: 71104 Views:3106 Replies:4 FollowUps:4
I am seeking opinions on what is best to do. I have a 80 series LC that is quite often parked in the garage for weeks on end as we don't need to use it except for trips. The cranking battery runs down so I now have a smart charger to keep the battery charged so as to not shorten its life. Should I disconnect the negative lead from the battery or is it ok to charge with the battery fully connected?.
WBS
Reply By: Geoff (Newcastle, NSW) - Friday, Jul 31, 2009 at 09:33
If you have a smart charger just connect it up and leave it.
The charger only does what your alternator does voltage wise so it's not going to harm anything.
Geoff
Geoff,
AnswerID: 376932
Follow Up By: vk1dx - Friday, Jul 31, 2009 at 10:46
Hi Geoff
I gather that would also be okay for a dual battery system. No isolation between them. Series 100 TD Toyota with factory dual batteries.
Am I correct?
FollowupID: 644362
Follow Up By: Geoff (Newcastle, NSW) - Friday, Jul 31, 2009 at 11:36
Sure would!
Geoff
Geoff,
FollowupID: 644369
Follow Up By: vk1dx - Friday, Jul 31, 2009 at 12:22
Thought so. After all two batteries in parallel is the same a s one larger one. Hey?
FollowupID: 644373
Follow Up By: Geoff (Newcastle, NSW) - Friday, Jul 31, 2009 at 13:23
That's exactly what the charger see's, one big battery.
Geoff
Geoff,
FollowupID: 644380
Reply By: ABR - SIDEWINDER - Friday, Jul 31, 2009 at 10:52
Hi WBS
No need to disconnect the battery/s make sure the charger floats at no more than 13.8V
Keep the electrolyte topped up if they are not M/free.
Do a weekly inspection if possible.
Derek from ABR
AnswerID: 376961
Reply By: get outmore - Friday, Jul 31, 2009 at 12:39
battery shouldnt be going flat (depending on your definition of weeks)
I would park mine up for a fortnight at a time and never had an issue starting it
now it only sits for 8 days between starts
AnswerID: 376977
Reply By: WBS - Friday, Jul 31, 2009 at 16:19
Thanks to everyone who responded. Your advice is appreciated.
WBS
AnswerID: 377009
