Built-in Bead Breaker
Submitted: Saturday, Aug 01, 2009 at 19:38
ThreadID: 71134 Views:3548 Replies:3 FollowUps:3
Score another for airspring suspension in the back...
Had for a long time a bead breaker in the kit - one of those ones with two hooked feet that are pulled together via a long screw jack to lock into the rim, and another screw jack set 90º to push the bead off the rim. Tried it today on my Bruiser tyres - 285/75/16 - would not even look at it. I am not a small person but with all my strength I could not get any purchase on the rim to start the process (and yes I DID deflate the tyre first!).
So what to do? Read a thread somewhere where someone modified a bit of square steel to fit into the tow bar receiver, which had a cutout for a jack head, the base of which when operated broke the bead.
I like that idea and started thinking a bit more. I have airsprings in the back (full coil replacement, not inserts), height controlled by electro-air switches. I found myself a brick, put it under the tow bar and got the missus to lower the suspension.
And it worked!
So now to design something a little more scientific, mainly to protect the tyre and stop the brick bit from slipping (safety), something with a foot and top made from channel to lock it into the towbar...
Gotta ring me welder mate...
viz
Reply By: ben_gv3 - Saturday, Aug 01, 2009 at 20:58
I just use the jack to replace the brick in your example. Have to be a bit careful with foot placement onto the tyre but I've used this method successfully. I don't have air springs but used the jack mechanism instead.
AnswerID: 377145
Follow Up By: viz - Saturday, Aug 01, 2009 at 21:25
Yeah - something I have seen before. My concern was to stop the jack from slipping. And something that was quick and ready to use. Not sure about what damage a misplaced jack base would do to the tyre as well.
I have some Oregon, I think 100x100 - I might shape a length to act as a foot and put a notch in the top or something to hold it in place...
Watch this space :) - I'm on a roll!
viz
FollowupID: 644518
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Aug 02, 2009 at 09:45
Check out my post 70970, some pics of a jack beadbreaker, I just used a piece of 1 1/2" black steel waterpipe welded to a piece of 50 x50 x 3 mm wall rhs tube. Jacking down on the tyre is very controlled and smooth and doesnt leave damage marks on the tyre like the beadbreakers. I have used this method on my spare recently and the tyre had been on the rim for 4 years, too easy.!! The idea i originally saw on the LCool site put there by own own Phil G on this site.. Michael
FollowupID: 644567
Reply By: Robin Miller - Sunday, Aug 02, 2009 at 10:04
Hi Viz
Glad you got it off .
Seen that both used sucessfully and unsucessfully.
Sometimes it pushes away from the rim and slips off.
I am sure with some thinking it could be made so that the force keeps it moving towards the rim.
I haven't yet not been able to get a tyre off with my Tyrepliers , but some have taken a bit off effort and stuffing around.
The real trick would be to help get the tyre fully off the rim.
In the meantime I make sure I break the bead on my tyres every so often just to be sure it isn't stuck when needed to be done.
AnswerID: 377220
Reply By: Geoff (Newcastle, NSW) - Sunday, Aug 02, 2009 at 18:36
viz,
You're a bloody good aussie bush bloke as my mate Stan is want to say.
That's his ultimate accolade for someone who can fix anything with nothing.
Just a thought, it might pay to look at doing both sides of the tyre simultaneously. See below,
With a bit of tought you should be able to reduce the chance of the wheel moving or flipping over as the pressure is applied.
Geoff
Geoff,
AnswerID: 377286
Follow Up By: viz - Sunday, Aug 02, 2009 at 18:50
Now ain't that a good idea!
Thanks for that :)
viz
FollowupID: 644614
