Tail lights and clearence lights blinking on caravan towed by BMW X5
Submitted: Saturday, Aug 01, 2009 at 21:25
ThreadID: 71142 Views:13704 Replies:8 FollowUps:9
We have taken delivery of a new caravan to tow with our BMW X5. We previously had trouble with a boat trailer which had LED lights until we had them changed to bulbs , so we requested incandescent external lights on the caravan and thought this would be trouble free. Now we have tried towing the caravan we find that , after about 1 minute with the headlights/tail lights on, the tail lights and clearance lights flash and keep flashing. The only suggested solution, to date, is to wire something into the car (quite expensive) or use a "shunt box" when towing. Why are we having problems when there are no external LEDs?
Reply By: Gone Bush (WA) - Saturday, Aug 01, 2009 at 21:36
Does your BMW have LED lights?
Reason I ask is that, with the 200 Series Landcruiser, an issue emerged when towing a van with NORMAL bulbs, not LEDs. The normal bulbs require more current than LEDs and the wiriing in the 200 was thin (all that's needed for LEDs) and could not deliver the required current that the van wanted to run non-LED lights.
Its trailer loom had to be upgraded.
I ordered our new van with LEDs because of this.
If this isn't the case, and you towed you boat with the BMW when you had those issues you mentioned, and you are still having issues with a new item being towed then you have to look at what is common between these two scenarios, and that is your BMW.
Have the wiring in the BMW checked for something loose somewhere.
AnswerID: 377156
Follow Up By: Gone Bush (WA) - Saturday, Aug 01, 2009 at 21:38
The only other thing I can think of is that the Tekonsha Voyager trailer brake controller cause a similar problem. Is your brake controller a Voyager?
If it is I suggest you upgrade to a Prodigy or P3.
FollowupID: 644521
Reply By: Flywest - Saturday, Aug 01, 2009 at 21:41
This post has been read by the moderation team and has been moderated due to a breach of The Inappropriate Rule .
Forum Moderation Team
AnswerID: 377158
Reply By: Member - Norm H (QLD) - Saturday, Aug 01, 2009 at 22:54
My l/rover disco 3 had same problem would not recognise led lights so had 12v
relays fitted in wiring to fool system that it was all 12v had no more problems
regards Norm H
AnswerID: 377164
Follow Up By: Member - Lotzi (QLD) - Sunday, Aug 02, 2009 at 08:47
Didn't BMW have something to do with Land Rover design a few years ago . . . ?
FollowupID: 644550
Reply By: Member - Doug T (NT) - Sunday, Aug 02, 2009 at 07:46
Got me whacked why anyone would request the old bulbs over LED's , take it back and have LED's fitted , I'd be asking the Missus for some facial cream to mask the red face ,
I can remember the Triple Roadtrains pre LED lights , the lead trailer was bright, trailer 2 was 50% and trailer 3 20%, nowadays all 3 trailers are the same brilliance ,
AnswerID: 377182
Follow Up By: Member - Lotzi (QLD) - Sunday, Aug 02, 2009 at 08:48
Spot on Doug !
FollowupID: 644552
Reply By: DIO - Sunday, Aug 02, 2009 at 11:39
This is apparently a know issue with BMWs and LEDs, owing to the configuration of their wiring and switching methods used. BMW have developed a 'link harness' that will overcome the issue. You could try this Link or search out a BMW owner's forum. Good luck.
AnswerID: 377233
Reply By: PajDIDauto - Sunday, Aug 02, 2009 at 12:12
This is a well known problem with many European and UK vehicles trying to run LED lights on a trailer or caravan. There has been a module developed in Australia to fix this, I saw it on one of the caravanning websites. It sits between your caravan and the BMW and is just a plug in unit. Check out this link.
http://www.4x4equip.com.au/listProduct/4x4+Accessories/LED+Trailer+Adaptor+Modules
AnswerID: 377238
Reply By: Member - Norm H (QLD) - Sunday, Aug 02, 2009 at 13:15
re led ring me 07 5432833
regards Norm H
AnswerID: 377245
Reply By: Kiwi Ray - Monday, Aug 03, 2009 at 16:29
hi
BMWs are a little strange in the way the ECU reads the power useage.
You will need to get BMW's tow light modul fitted.
I have tried a number of other ways and always come up with faults.
No faults with the genuine unit
Ray
AnswerID: 377393
