Is there any way to tell the kva of a generator?
Submitted: Sunday, Aug 02, 2009 at 08:37
ThreadID: 71148 Views:3529 Replies:2 FollowUps:4
G'day all, how can I tell the kva rating of a generator, is it possible & how? Thanks in anticipation, regards, aussiedingo
Reply By: Bonz (Vic) - Thoughtfully- Sunday, Aug 02, 2009 at 10:12
There should be a nameplate much like the one on your car somewhere on the generator, alternately, some have the rating stamped into the casting body of the unit.
Good luck
AnswerID: 377222
Reply By: Member - Garth J (NSW) - Sunday, Aug 02, 2009 at 12:20
Barring having the info from the nameplate or the manual thats a good question.
If you know the power output in watts then you could for a ballpark figure multiply the power by .8 or .9 for a ballpark number.
eg 2000Watts
equals
2000 * .8 = 1600kVA
If you know the power factor figure all the better!!
This example is what a honda 2.0ei gives basically.
Garth
AnswerID: 377242
Follow Up By: Member - Garth J (NSW) - Sunday, Aug 02, 2009 at 12:22
Doh,
Make tha VA not kVA.
Would be 1.6kVA
Garth
FollowupID: 644589
Follow Up By: Robin Miller - Sunday, Aug 02, 2009 at 14:00
Hi Garth
Other way round
2000 VA = 1600 watts (if PF - 0.8)
Watts is real or heating power
FollowupID: 644591
Follow Up By: Member - Garth J (NSW) - Sunday, Aug 02, 2009 at 14:43
Thanks Robin,
Too hasty in my reply........
and a while since I've done the theory!!!!!
and the maths!!!!!!!
Garth
FollowupID: 644596
Follow Up By: Member - JohnR (Vic) - Sunday, Aug 02, 2009 at 18:15
Come on Garth, you have been thinking too many lyrics instead of expecting everything to add up. You calling back this way after your South Aussie trip in September? We hope to get across to Eyre Peninsula after the appointed time for a short time.
FollowupID: 644608
