timing belt
Submitted: Sunday, Aug 02, 2009 at 16:54
ThreadID: 71166 Views:2980 Replies:2 FollowUps:6
hi there, can anyone tell me how to resset the warning light for the timing belt change at 150000k. wehicle is a toyota hilux 2002 turbo diesel 3l engine ( 1kz-te). all help appreciated. Gerry
Reply By: donk - Sunday, Aug 02, 2009 at 17:43
On this model you need to remove the instrument cluster & swap a screw from the original position to a alternate position in the cluster rear to reset the light
Regards Don
AnswerID: 377275
Reply By: WYSIWYG (Bundaberg Qld) - Sunday, Aug 02, 2009 at 18:44
Hi Benq,
try thread 12211 (archived) it has some info on how to remove the speedo assembly etc.
AnswerID: 377287
Follow Up By: Lex M (Brisbane) - Sunday, Aug 02, 2009 at 19:15
Hmmm bit different to this model
Allow plenty of time if you haven't done it before.
From memory.
Remove drivers side scuff plate from door opening.
Remove kick panel
Remove lower dash panel(under steering wheel). Disconnect instrument dimmer plug and bonnet pull as it comes out.
Remove audio surround panel ,remove ash tray to access screw
Remove instrument cluster surround panel, tight fit past steering wheel.
Remove instrument panel, disconnect plugs at top back as it comes out. Very tight fit past steering wheel
Shift timing belt screw to other hole.
And as they say in the classics:-
"Reverse the procedure" to put it all back
FollowupID: 644625
Follow Up By: Marny - Sunday, Aug 02, 2009 at 20:57
Thank god I dont have a toyota!! That seems an awful lot to make a light go out? :>) marn
FollowupID: 644647
Follow Up By: Member - Johny boy (NSW) - Sunday, Aug 02, 2009 at 21:03
Mate on my 100ser I believe you just turn the key to ignition then off then on to some sequence and that turns the light off , maybe yours might be the same as they are both Toyota's ??
FollowupID: 644648
Follow Up By: donk - Sunday, Aug 02, 2009 at 21:26
No they are not
The hilux is as we described
Regards Don
FollowupID: 644653
Follow Up By: Member - Johny boy (NSW) - Sunday, Aug 02, 2009 at 21:36
What a shame Don as this Idea sounds much easier ,I suppose you need some sort of an edge when your paying the extra $$$$ LOL!!!
FollowupID: 644656
Follow Up By: Lex M (Brisbane) - Monday, Aug 03, 2009 at 09:01
It takes longer to turn the light off than it takes to change the belt. :-)
FollowupID: 644709
