K1 line Plot
Submitted: Tuesday, Aug 04, 2009 at 17:48
Robin Miller
Hi Guys
Surprisingly I have been unable to find a K1 line plot and wonder if anyone can help with this.
Treks here, have almost every other Simpson track , but I don't seem to be ab le to come up with this. Couldn't even find it on 4x4 earth.
Its the track from
Warburton crossing up to Poeppels.
I seem to remember it is fairly straightforword and wonder if anyone could
hazard a guess about when it will open - only guesses pre-september will make me smile.
Reply By: Muddie - Tuesday, Aug 04, 2009 at 20:17
Hi Robin, I am also off to the Simpson Friday 14th and have been Nav planning for a few weeks. I just use a combination of OziExplorer with the better scaled Simpson 500 map to get the rough lat and long on the tracks then use it to locate the track on Google earth and follow it as far as you need, the detail is great, you can get as many points as you want.
regards David
377565
Follow Up By: Robin Miller - Tuesday, Aug 04, 2009 at 21:38
Hi David
Could do that I guess , actually a bit surprized that its not in exploroz treks.
Maybe you or I might add it one day , but hundreds would have plotted it , and as my GPS can drive those plots it just would be convient to have it.
You have a good trip won't you , for me I can wait till just after the
Birdsville races and only plan on going if tracks like the K1 open up.
644944
Follow Up By: Muddie - Tuesday, Aug 04, 2009 at 22:01
Thanks Robin
I am sure someone will come up with a plot file.
Google earth is great for planning I hope to do another confluence this year and have plotted a path up the swales.
644945
Reply By: Richard Kovac - Tuesday, Aug 04, 2009 at 22:11
Robin
Try
K1 line
Richard
377583
Follow Up By: Robin Miller - Wednesday, Aug 05, 2009 at 07:49
Hi Richard
Thanks , that should help a lot.
I am intrigued as to how you found that plot it has an ID of 611 , but I cannot find that through the Treks menu.
The treks menu list several Simpson tracks , but not that one.
644959
Follow Up By: Richard Kovac - Wednesday, Aug 05, 2009 at 15:04
Robin
go to plotswap page on the map hover hand pointer near where you what to go if there is a plot there will be a track, zoom in click track and a list of plots and or treks will appear, just pick the one you want.
Richard
645047
Follow Up By: Robin Miller - Wednesday, Aug 05, 2009 at 21:12
Going thru the map sure worked Richard , must remember not to rely on the index next time, thanks
645105
Reply By: Member Brian (Gold Coast) - Wednesday, Aug 05, 2009 at 07:14
Hi Robin,
We drove the K1 last year. Although hard to follow the track in
places, probably as it is less used than others out there, it is as you mentioned, pretty straightforward. Unfortunately, we didn't plot it while we were there.
Brian
377603
Follow Up By: Robin Miller - Wednesday, Aug 05, 2009 at 08:00
Hi Brian
Seem to remember now you went that way, and the biggest obstacle was that big puddle west of
Birdsville.
644962
Reply By: Member - Chris & Debbie (QLD) - Wednesday, Aug 05, 2009 at 11:16
Hi Robin
Which part of the K1 you after I have a plot here taken in 2008 from the Birdsvile track to the QAA Line, which includes Yelpawaralina Track,
Warburton Track and the K1 Line. If it's still required let me know and ill cut out the section needed and email it to you.
Chris
377625
Follow Up By: Robin Miller - Wednesday, Aug 05, 2009 at 12:01
Hello Chris
That would be nice, I have parts of it now, but not the
Warburton end.
I can do the cutting work to save your time if you like , just send whatever you have.
645013
Follow Up By: ExplorOz - David & Michelle - Wednesday, Aug 05, 2009 at 12:47
Just quickly Robin, but I think that bit is in the "Inside Track" trek note.
MM
645019
Follow Up By: ExplorOz - David & Michelle - Wednesday, Aug 05, 2009 at 12:52
DOH, meant
Rig Road trek note.
MM
645021
Follow Up By: Member - Chris & Debbie (QLD) - Wednesday, Aug 05, 2009 at 13:34
Email sent
645028
Follow Up By: Robin Miller - Wednesday, Aug 05, 2009 at 21:11
Thanks Guys , your plot loaded up just perfectly Chris.
Hope to return the favour one day.
645104
