Tent alarm
Submitted: Tuesday, Aug 04, 2009 at 18:33
ThreadID: 71212 Views:8284 Replies:11 FollowUps:4
Now, I know this may sound a little strange but, does anyone know of an alarm for tents, campers or caravans ect.
I was thinking of a remote armed PIR type. Cannot be movement type for obvious reasons.
regards
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
Reply By: Member - Josh (VIC) - Tuesday, Aug 04, 2009 at 19:08
8 ft snake works well lol. Someone suggested used a door alarm type, the one that sounds when you walk through them.
Josh
AnswerID: 377552
Follow Up By: Member - Wim (Qld) - Tuesday, Aug 04, 2009 at 19:29
Josh
I can see where your coming from with both suggestions but I was hopping for some sort of PIR type.
If all else fails We do have a 3 meter python which frequents our yard.
regards
Camper setup
VKS 737 Mobile 0091
Selcall 0091
FollowupID: 644917
Reply By: Member - Mick O (VIC) - Tuesday, Aug 04, 2009 at 20:26
G'day Wim,
yes there is a tent alarm. They are very much like a padlock and lock the zip tabs together. They sound an audible alarm if disturbed. Not sure of the cost but I think somewhere between $60-$100. I've seen them at Anaconda and some of the outdoor stores such as Paddy Pallin. There is also one for wrapping around your pack so you could adapt that as well.
Hope that helps.
Cheers Mick
AnswerID: 377568
Reply By: Member - Jack - Tuesday, Aug 04, 2009 at 20:40
I have used a personal alarm (of the type that have a pin, and when you pull it out it gives off a very loud, shrill sound). Anchour it, tie the pin to the tent flap so that it is tight-ish. Someone enters the tent the alarm goes off .. and if luck is on your side, they will also have permanent partial hearing loss.
Jack
AnswerID: 377570
Reply By: OzTroopy - Tuesday, Aug 04, 2009 at 21:51
As long as you have 12v supply in your van ... any of the normal house alarms will work.
dick smith / jaycar etc have a range of battery operated PIR types suitable for tent applications.
AnswerID: 377579
Reply By: kingswoodwagon - Tuesday, Aug 04, 2009 at 22:21
I used a roof rack alarm which would be triggered if the weight of my windsurfing boards were lifted, this was connected to my cars air horns. The trigger was simply 4 small micro switches. I used them in my tent much the same - connected to the car airhorns. If the gear in the tent was disturbed or if the wires to the car were cut - the air horns would sound.
It was a pretty clunky system, probably more of a deterrent, but I never had anything stolen.
have fun
AnswerID: 377584
Reply By: Member - Wim (Qld) - Wednesday, Aug 05, 2009 at 07:08
Thanks to all for the replies.
Food for thought.
regards
Camper setup
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 377602
Follow Up By: Member - Johny boy (NSW) - Wednesday, Aug 05, 2009 at 16:24
Hi Wim ,you said PIR type alarm but you don't want a motion sensor I think you will find that PIR stands for Passive Infra red ,that's what is used in a motion detector,if I were you I would go to the camping shops as suggested above but avoid any motion detector as they WILL false alarm sooner or later and you might come back to camp finding an angry mob of campers waiting for you LOL!
Cheers.
FollowupID: 645061
Follow Up By: Member - Wim (Qld) - Thursday, Aug 06, 2009 at 09:37
Johny boy
The reason for thinking about PIR is that it would only trigger on a heat source hence why I would stay away from ultrasonic.
We would not normally be camp with others. Would be used to deter inquisitive passers by when we are camped alone.
More a fishing expedition than any thing else.
regards
Camper setup
VKS 737 Mobile 0091
Selcall 0091
FollowupID: 645160
Reply By: Member - Troll 81 (QLD) - Wednesday, Aug 05, 2009 at 08:33
I looked into this and there are a couple of things on the market but I was after an infrared motion sensor type thing. Just to wake me up when there’s some sort of animal near the camp sitethe alarm will sound or a light will turn on. Pretty sure JayCar sells something like that but it was all too hard in the end for me to follow up
AnswerID: 377608
Reply By: Member - Kiwi Kia - Wednesday, Aug 05, 2009 at 18:59
In the old American war movies they used an empty baked beans can with a couple of stones in it and the can tied to a bit of string. Can rattled when nthe string moved - well it always worked in the movies :-))
AnswerID: 377678
Reply By: Pomgonewalkabout - Wednesday, Aug 05, 2009 at 19:06
Just a thought but where will you be when the alarm goes off?
It's bad enough being on a campsite with gennies going.
cheers Eric
AnswerID: 377679
Reply By: Member - Mike DID - Wednesday, Aug 05, 2009 at 21:21
Bunnings sell a Wireless system for abt $70 that use a PIR sensor.
AnswerID: 377706
Reply By: MrBitchi (QLD) - Thursday, Aug 06, 2009 at 13:32
Doberman Infrared Perimeter alarm
AnswerID: 377795
Follow Up By: Member - Wim (Qld) - Thursday, Aug 06, 2009 at 13:49
Hi John.
Another one I found http://www.stealarmor.com/
A bit on the pricy side but interesting none the less.
I'm not sure how practical the hole thing is.
See you at St George.
Camper setup
VKS 737 Mobile 0091
Selcall 0091
FollowupID: 645186
