mobile phones
Submitted: Wednesday, Aug 05, 2009 at 00:20
ThreadID: 71222 Views:3460 Replies:8 FollowUps:4
Hi all
we have data packs on our mobile phones are we able to plug our phones into a laptop and use them instead of the telstra stick when we are on the road would save getting another modem if we can use the phone as one. or are the modem sticks far supperior?
Reply By: Member - Graham H (QLD) - Wednesday, Aug 05, 2009 at 00:27
Use the phones as they usually have better reception than a USB modem.
However only Telstra is worthwhile away from main centres despite what some may try to tell you.
Would work even better if you can also plug in an external aerial.
I was nearly 50k out of Carnarvon the other day when my phone rang Nearly had a personal accident ( have to watch **** these days) LOL
took it out of the aerial cradle and it dropped out
Put it back and turned loudspeaker on and we yacked all the way to Carnarvon no trouble
Its a Nokia 6120. with a Force inductive cradle and an RFI multiband aerial.
$175 at a Telstra shop for the two bits.
AnswerID: 377595
Reply By: Ray - Wednesday, Aug 05, 2009 at 07:59
Yes you can do it with your mobile 'phone but it is quite expensive
AnswerID: 377604
Follow Up By: bruce - Wednesday, Aug 05, 2009 at 10:45
Actually Ray it is not all that expensive at all when you consider just how much you really need to use the internet while traveling...you already have a modem in your phone...a $10 data pack for a month gives you 150mb with the option of topping up or buying more mb if you need it....we were away not long ago for 3 weeks and 150mb was heaps just for browsing, banking and sending of a few emails with photos and the next G phone speed is also a plus over the Big Muddle modem.....cheers
FollowupID: 644992
Follow Up By: DesF - Wednesday, Aug 05, 2009 at 16:03
Have to agree with Bruce, we have a Nokia 6120 and a $10.00 data pack and it is ample for mail and the odd look up of places while we are travelling. we just park at Macca's when we need to do a lot of online stuff.
I just check the mail on my ISP home page and delete any huge files before I down load the mail.
last trip even did some Skype voice calls and the didn't use very much either.
Very happy with the coverage as well, Next G seems to be the only way to go.
Cheers Des.
FollowupID: 645055
Reply By: Gone Bush (WA) - Wednesday, Aug 05, 2009 at 10:57
Here are the prices for Mobile as a Modem Data Packs from Telstra:
Mobile as Modem Browsing Packs
$59 Browsing Pack
Included MB per month: 1GB
$89 Browsing Pack
Included MB per month: 5GB
$119 Browsing Pack
Included MB per month: 9GB
AnswerID: 377619
Follow Up By: DesF - Wednesday, Aug 05, 2009 at 16:07
There are two listings of data packs ,( I go into Bigpond site ) we use $10.00 for 150meg or $29.50 for 300, If you are running out you can just ring up and they will upgrade you to the next pack on the spot. they do have a 1gig ( I think ) for about $59.95 a month.
Cheers Des.
FollowupID: 645057
Follow Up By: Gone Bush (WA) - Wednesday, Aug 05, 2009 at 16:45
Yes, the Telstra site is a minefield of poorly explained information. If you look here:
Site Link
you can see Browsing Packs which are applicable if you are getting on the net ON your phone, ie, viewing web pages on the screen of your phone.
The other, a bit further down the page is for when you are using your mobile, connected to your laptop via a USB cable, as a modem to get onto the net.
FollowupID: 645063
Reply By: Out and About - Wednesday, Aug 05, 2009 at 11:00
We have a Telstra PrePaid USB stick and 2 Telstra Next G Phones. I have connected to the internet using both the phones and the USB stick. The phones (with an arial attached) give marginally better coverage than the stick alone. However, the improvement is not that great.
We have a datapack attached to the USB stick (the exact some ones are avialble as for the phones) and we do not actually use it prepaid.
I find the stick the best option as it is less fiddly than connecting up the phone. However I got my stick for free in a Telstra promotion - otherwsie I probably would have not bothered to pay the $150 it costs otherwsie.
AnswerID: 377621
Reply By: The Lobster - Wednesday, Aug 05, 2009 at 11:25
To give some more detail, the easiest way to use your phone as a modem is to install the software that comes with most phones, on your laptop. I have a Sony Ericsson W705 and when I plug it in, the software recognises it and asks me what mode I want the phone to be in, modem, mass storage, media transfer etc. I choose modem, it connects and I'm good to go. My previous Motorola V6 had a similar process, and I believe the nokias are similar also. Just make sure you have the software installed and working before you go.
As others have said, an external aerial would give you better coverage, but there are few phones these days that actually have an external aerial port/plug. There are mixed reports on the induction type patch connectors that are commonly offered for Nokias etc. I would do some decent research on your phone model before shelling out too many $ on an aerial. Make sure it's going to be worth it first, or make sure you can return the aerial etc if it doesn't help much.
Hope that helps.
matt
AnswerID: 377627
Reply By: Tardust - Wednesday, Aug 05, 2009 at 14:14
I searched long and high for the most economic solution. Most mobiles can act as modems, the differential is the aerial. In traveling it is best to have a 'rural' capable phone, there are two prepaid choices under $200 currently with telstra.. I chose the samsung as it had the better aerial and 'nextG' capabilities, in the higher bracket there are more options. Telstra is the only way to go for remote areas.. tho dodo offers options for reasonable economic coverage in many areas and depending on your travel may well suit the coastal traveler. Dodo also offers a longer expiry period than telstra.
Phones, acting as a modem is more practical than a modem stick and more efficient... tho I use a modem stick at times for convenience but I have one of the older more powerful dongles and it has been unlocked to take a variety of telco carriers. Telstra's modem stick can only take telstra sms I have been told. I have a tendancy to shop around for the most economic data carrier available in any given area depending on my length of stay.
On a prepaid contract with telstra you can purchase data packs from your 'prepaid credit' For $20 you can get 150mg for a month, this on a scale of volume related to $ up to $100 for 6g... expiry is within the month tho. I usually just buy a data pack for the time I will be traveling, which can also be done over my mobile phone on the recharge credit remaining, converting phone call credit to data credit. I used to be able to get a $10 data pack for 75mg but it seem it isnt available anymore.
Install your phones drivers into your laptop.. with windows the process is simple and usually a self install, with linux you need a little more nouse but it can be done... I have successfully installed the modem dongle on my little Asus Eee PC (linux) and I use this for communications on the road but will soon attempt it with the phone as I will need telstra coverage with the baby Asus soon. While on my bigger laptop running XP, it all works a treat but I have found the dongle is more powerful than the phone in reception but this is an older dongle (stick) one of the white oval type, the newer ones arent as powerful unfortunately. I use the dongle for all links bar the telstra link that is the only one available in many tricky area's or places shadowed by mountains, escarpments etc. When I need to link to telstra which on the whole is more expensive, I use only the mobile and can arrange a data pack when needed via the mobile phone, which then give me computer access to the internet.
Variety is the spice...
AnswerID: 377646
Reply By: ExplorOz - David & Michelle - Wednesday, Aug 05, 2009 at 15:14
We use a data pack on our phones and use these all the time when travelling - I even support and update software on ExplorOz via my mobile phone modem setup sitting on the beach at Ningaloo. All we have are the $10 for 150MB options on both mine and Michelle's phone - this is enough and we use it everyday as I have installed the Mail for Exchange software and read all email on my phone (Mokia 6120).
Also using this option we are about to launch a new ExplorOz tracking mobile application that works to support real time GPS tracking via your mobile phone and we calculate that with a 150MB per month allowance we can send more than 30 million position updates to the server - this equates to being able to live track you on your trip taking waypoints at less than 50 metre intervals and uploading them in real time to the server even it you travel at 100km/hr 24hrs a day for the whole month.
This setup if excellent and if you need more data for photos update or something then you can just buy a larger allowance for more bucks and then revert when you get home down to the $10. it is easy and can be done on the phone to Telstra or at the Shops.
DM
AnswerID: 377654
Reply By: Tars - Monday, Aug 10, 2009 at 09:27
Hi All
Quick question - as well as getting charged via the data pack do you also get charged for the phone call to connect to the internet on the mobile and is it timed ie just as if you are making a normal phone call?
Tara
AnswerID: 378340
