pajero front end lift 2"
Submitted: Wednesday, Aug 05, 2009 at 16:50
ThreadID: 71233 Views:2829 Replies:5 FollowUps:2
can i adjust the torsion bars to achieve this? if so how,and do i need any special tools !!!
Reply By: Member - Oldplodder (QLD) - Wednesday, Aug 05, 2009 at 17:16
No, in a simple answer.
Check your bump stop clearances, the upper and lower A arms should be equally distant from the lower and upper bump stops. The front end does sag with age.
You might be able to squeeze 5 to 10mm more by going for a slightly higher setting.
For more clearance, it is easier to go for bigger tyres.
To adjust, jack up the front end and adjust the bolt at the rear of the torsion bar.
Make sure you have the same height both sides. No special tools required.
AnswerID: 377662
Reply By: nige w - Wednesday, Aug 05, 2009 at 17:31
thanks oldplodder,will give it a go ! only bought it 4 mths ago [ 1st 4x4 ]
AnswerID: 377664
Reply By: marq - Wednesday, Aug 05, 2009 at 18:13
Model?
AnswerID: 377672
Follow Up By: Member - Oldplodder (QLD) - Thursday, Aug 06, 2009 at 07:55
If it has torsion bars in the front it must be NA to NL. ??
NP on had coil springs. ??
My NJ looks almost the same underneath the front as my old NB.
FollowupID: 645149
Follow Up By: nige w - Thursday, Aug 06, 2009 at 21:00
yes its an NJ
FollowupID: 645245
Reply By: Member - Kiwi Kia - Wednesday, Aug 05, 2009 at 18:47
Do you realise that the vehicle will become less stable and you will get accelerated tyre wear if you do this ?
KK
AnswerID: 377675
Reply By: nige w - Wednesday, Aug 05, 2009 at 20:56
hi marq n kk thanks for your replies, it,s a 1995 3.5 nj lwb and didnt know about the tyre wear, anyone know the best option? back end,s nice n high [may have been uprated for towing]maybe! . i just want it to look like its not going down hill all the time and the extra clearance would be usefull for offroad
AnswerID: 377699
