Mechanical Question - Worn Ball Joints
Submitted: Wednesday, Aug 05, 2009 at 20:02
ThreadID: 71238 Views:5142 Replies:8 FollowUps:0
Hi All
I had a bit of a knocking sound come from the front end of my 2000 Hilux.
I took it along to the RAC and they said the Ball Joints were wearing and would need replacing. The car's done about 195,000km and I don't think they've ever been done.
The knocking has probably been getting gradually worse over the last 2000km or so and isn't really noticeable on flat roads, but is slowly getting noiser.
What I was wondering was if it would be ok to leave the Ball Joints getting fixed until the next service in about 5000km, or will damage result if they are not done promptly? I mainly drive on flat roads and won't be doing any off road driving until after the next service.
Reply By: Member - Toyocrusa (NSW) - Wednesday, Aug 05, 2009 at 20:23
Hi Ozwasp. The ball joints are the connectors for your suspension and steering so are an important part of the geometry. In extreme cases they can come apart creating an extremely dangerous situation. I would have an expert give a guide to how quickly they require replacement to avoid any danger of a ball joint failure. Regards, Bob.
AnswerID: 377692
Reply By: Member - Porl - Wednesday, Aug 05, 2009 at 20:29
I have a 2000 hilux, surprised you can hear anything over the motor, is it the diesel? Either way same running gear I think so when do you hear the knocking? On turning or idling or driving at low speed etc?
AnswerID: 377694
Reply By: splits - Wednesday, Aug 05, 2009 at 22:00
ozwasp
Nobody can answer that question without seeing them. When a ball joint gets to the audible knocking stage, they are usually very well worn and can be dangerous.
Do they have grease nipples on them? Toyota fits little screw in plugs and they should be removed and replaced with nipples. If yours have nipples and they have been regularly greased, particularly after driving through deep water, then they should last longer than 195,000 ks. If they don't have them then that would be why the RAC has told you they are worn. There would be a good chance they are rusty inside and could easily be on the verge of coming apart.
I assume the RAC is talking about the top joints. They are the load bearing ones on your type of suspension and usually wear out far faster than the bottom. The bottom ones are little more than locators and don't have anywhere near as much stress on them. The weight of the vehicle is forcing the two halves of the top joints together and this is why you don't hear anything on flat smooth roads. The moment the weight is eased on the joint e.g the wheel leaving the ground, the weight of the wheel, hub, brakes etc
as they hang down will try and pull the joint apart. If the wear is bad enough it will let go and you will be in big trouble.
Any mechanic who has been in the trade for a few years will have seen a few ball joints break so don't take any chances, replace them immediately.
AnswerID: 377721
Reply By: vk1dx - Wednesday, Aug 05, 2009 at 22:14
Get it done now. Its not worth the risk. Or take it off the road.
Thats what we would do.
AnswerID: 377728
Reply By: Travelin OZ - Wednesday, Aug 05, 2009 at 23:45
If you snap a ball joint in half you are a passenger in a very dangerous position, I would have it towed on a tilt tray to have it fixed tomorrow.
AnswerID: 377748
Reply By: Member - Brian R (WA) - Wednesday, Aug 05, 2009 at 23:45
HI ozwasp
Yes I agree with all the above......leaving these things until whenever is not a good practice....get it sorted and get back to enjoying
Brian R
AnswerID: 377749
Reply By: Member - Oldplodder (QLD) - Thursday, Aug 06, 2009 at 07:52
Besides the extra wear to the tyres by the steering flopping in and out of alignment. Get it done soon.
AnswerID: 377760
Reply By: gbc - Thursday, Aug 06, 2009 at 18:13
My 2003 'lux running 31" tyres ate pitman/idlers for breakfast. Well not that bad, but had the front end done twice in 160k. It was a well used vehicle offroad though. Had grease nipples etc tapped into the pitman and all. The advice I got from various sources was "use genuine parts". The first rebuild I used ebay parts and they failed quickly. It's not a big job to do the ball joints - there are two. Get the whole front end checked - it'll be due.
AnswerID: 377829
