Is a Speedo mod needed
Submitted: Wednesday, Aug 05, 2009 at 20:44
Member - Johny boy (NSW)
Hi all if I was to go from a 275/70/ r16 to a 285/75/r16 will my speedo read that I'm doing lets say 110 kph when I'm really dong more like 115kph
or is it the opposite like I'm doing 110kph but I'm really doing 105kph ,i just went over all this with my brother and we really don't know ,so do any of you guys know the math behind it ?
Reply By: Member - Toyocrusa (NSW) - Wednesday, Aug 05, 2009 at 20:50
Hi John. The larger the tyre diameter the Slower the speedo will read. Best to obtain/borrow a GPS and check your speed accurately against the vehicle speedo. This will show any error. Bob.
377698
Reply By: viz - Wednesday, Aug 05, 2009 at 21:01
Speedo will read about 4-5km slow. 95 km/hr indicated will be 100 km/hr true
viz
377700
Follow Up By: Member - Johny boy (NSW) - Thursday, Aug 06, 2009 at 08:52
thanks Viz, that's right:)
645156
Reply By: Member - Graham H (QLD) - Wednesday, Aug 05, 2009 at 21:05
Go here and type in your sizes It will tell you the difference
http://www.rims-n-tires.com/rt_specs.jsp
You can buy a correction kit from Jaycar for $50 or a ready made one from Marks Adapters (google It) for $150.
377702
Follow Up By: Member - Johny boy (NSW) - Thursday, Aug 06, 2009 at 08:46
Hi Graham,
What do you get in a correction kit ?
645154
Follow Up By: Member - Graham H (QLD) - Thursday, Aug 06, 2009 at 10:48
None
Havent changed tyre size
645173
Reply By: Madfisher - Wednesday, Aug 05, 2009 at 21:33
Mate with a toyota it will correct it to accurate. They always read fast by 5 to 10%.
Cheers Pete
377709
Follow Up By: Member - Graham H (QLD) - Thursday, Aug 06, 2009 at 10:50
Strange My 100 ser and my GPS give identical readings at 100kph
Running 275 x70 x16 BFG AT's
645174
Follow Up By: viz - Thursday, Aug 06, 2009 at 12:05
Mine too when it was running stock tyres. So does the Missus's Carolla. You'd think that German technology would be accurate too but me Merc over reads by 4-6 kays on stock tyres. But the Toyotas are dead accurate.
viz
645178
Reply By: Gone Bush (WA) - Wednesday, Aug 05, 2009 at 22:01
John,
go straight to the
tyre size calculator on this site and use the tyre comparison section:
ExplorOz Tyre Size Comparison
377722
Follow Up By: Member - Johny boy (NSW) - Thursday, Aug 06, 2009 at 08:51
Hi G.B,
Thanks that made things so easy ,so if I understood correctly that means when I go up in size it will read for instance 100kph but I'm really doing 105.1kph
I have asked blokes that have gone up in size and they have said they don't notice any diff in
fuel consumption or loss of power so what do you believe LOL!!
Cheers.
645155
Reply By: Drew - Karratha - Wednesday, Aug 05, 2009 at 22:11
Just realise that the 285/75's will increase your
fuel consumption and reduce the noticable power from your engine. I changed my 265/75 16's for 285/75 16's and only lasted one day before I swapped them back -
mine is an 80 series diesel with gas injection. It could barely accelerate when doing 110.... any slight
hill would slow it down... Yours might be a lot different with the Safari Turbo.
There was a 4km/hr difference in speedo between the tyres but the speedo was only out by 2km/hr of actual speed on the gps with the bigger tyres (if this makes sense...)
Drew
377727
Reply By: Member - Oldplodder (QLD) - Thursday, Aug 06, 2009 at 07:50
When I checked out going from 235/75/15 (29") to 235/85/16 (32") on the Paj, the requirement was that any change more than 10% requires a recalibration.
Check with your state registration authority.
Did a GPS check after the change and I was only under reading by 4%, i.e. 100 on the dial is 104 over the ground. Speedo was over reading in the first place.
So haven't worried, just sit on 95 by the dial in a 100 zone and pass every one. :o)
PS - when the tyres are down in tread, i.e. tyre is 20mm smaller in diameter, difference is only 2%.
377759
Reply By: Member - Greg T (ACT) - Thursday, Aug 06, 2009 at 13:49
i went fron 265/75/16 to 285/75/16 on the GU and the Spedo is 100% accruate now. checked this with 2 Navmans and Ozi Exporer, strangly, all 4 speed measures came in at 100km/h
377800
Reply By: Member - Tony & Julie (FNQ) - Thursday, Aug 06, 2009 at 16:18
Johny Boy - If you look in members file swap I placed and others have placed a
Tyre Size calculator that will show multiple tyre sizes with speedo readings.
If you can not find email me and I will send you both spreadsheets, and anyone who wants a copy.
You can put up to 5 tyre sizes in at a time. Cheers Tony
377811
Reply By: Wherehegon - Thursday, Aug 06, 2009 at 21:56
I went from 70 profile to 75 on the old prado. The speedo was out already from new by 4klm per hour so with the 70 series on it I was showing 110 on the speedo but the GPS showing 106, when I put the 75 profile on, 110 on the speedo, 110 on the GPS so it was spot on. You might find your speedo the same. My wifes Toyota is out by 6k, showing 110 on speedo, gps showing 104. They are allowed to be out this way but not the other way around....Regards Steve M
377879
