Another Nissan loses a wheel
Submitted: Wednesday, Aug 05, 2009 at 21:39
Member - Michael O (NSW)
Just travelled 7300km through Queensland. Home for a week and the rear passenger side wheel falls off at 20km/h in the middle of Wagga!!
Unfortunately SWMBO was driving as I had an "important appointment" with the V8's at Sandown in
Melbourne.
Here's the interesting bit...
I had an accident in
Canberra in 2006 when an errant ute ploughed into that very same wheel. It was all checked and repaired at the time as I was paranoid about something breaking later on.
Anyways I got new BFG's to go to
Cairns and they were fitted by a local business. Is it possible that a wheel stud was damaged in the original accident and broke on the Qld corrugations? The rear of the lost wheel showed all the other studs had been wearing on their mounting holes for some time (holes worn into oval shaped holes) but the last had no marks at all and was still perfectly round (as if the stud wasn't there...)
Now if the other wheel studs were "tight", would it matter if ONE stud broke off? Could the wheel still work loose? The insurance company says no. If the stud had a stress fracture, could it be overtightened and break?
Lucky for me, driver and passengers (ie 2 kids) are all
well. The thought of losing a wheel out the back of
Charleville while approaching a roadtrain at 120 gives me nightmares...
Penny for your thoughts...
Reply By: Member - Graham H (QLD) - Wednesday, Aug 05, 2009 at 21:46
If you were doing 120 in Queerland you would have more to worry about than roadtrains.
Spooks in the bushes with cameras.
LOL
377716
Follow Up By: solo - Wednesday, Aug 05, 2009 at 22:40
I lost the rear passenger side wheel on my Nissan at 110km but fortunately it went in a straight line. I had the van on the day before.
Recently I had new tyres put on and I cautioned the Tyre Guy to make sure the nuts were good and tight! He showed me his metre long socket spanner and assured me that they would be be
well tensioned. After about 200km and a bit of
unsealed road I thought I'd better check...just to be sure.
Despite his brute tension bar I could now get an extra quarter turn on each nut with standard wheel wrench.
The lesson Ive learned is to check the tension a couple of times in the first 1000km after a wheel change. They seem to be OK after that. Rear left seems to be the most susceptible.
Cheers SOLO
645128
Reply By: donk - Wednesday, Aug 05, 2009 at 23:04
In the past there have been lots of threads on Patrols with factory alloys loosing
wheels (i can remember any cases when steel
wheels have been fitted) but i dont remember reading if there had been a definite cause found
Regards Don
377741
Reply By: splits - Thursday, Aug 06, 2009 at 00:08
Michael
I have seen wheel bearing cones cracked in half after impacts with gutters so I suppose a collision with another car could damage a wheel stud. The problem with studs is you usually can't see just by looking at them.
The most common problem with
wheels coming off seems to be nut tension and doing then up very tight is not the answer. The importance of this was stressed during a trade course at TAFE many years ago. We were shown how the area around the stud on steel
wheels does not touch the hub. It is designed to bend as
the nut is brought up to the correct tension. Tapered holes in alloy
wheels are said to enlage slightly as
the nut is tightened. I have used tension wrenches on all of my cars ever since and never had a problem.
If you had your tyres fitted by a tyre service using a rattle gun then that could have been the start of your problems. The tension on my six stud ute for example is 25 ft lbs less than the five stud 2wd version of the same model. The five stud Landcruiser is double the tension of
mine. If you get it wrong you will end up with either loose nuts or stretched studs that are on their way to breaking. The nuts should also be tightened in the correct sequencs.
If your tyre service did not adjust their gun to the correct tension for your car and the gun was accurate then who knows what they set them at.
The following two links give some usefull information on wheel nut tensions and causes of stud failure. The first mentions near side rear
wheels coming loose and possible causes of it..
http://www.boltscience.com/pages/failure4.htmhttp://www.caravanandmotorhomebooks.com/articles/why_wheels_fall_off.html
377750
Follow Up By: Member - Allan B (QLD) - Thursday, Aug 06, 2009 at 10:13
I have watched tyre service mechanics fit
wheels to vehicles on many occasions and have never seen them adjust their rattle gun tension at any time. It seems all vehicles get the same tension.
645167
Reply By: MrBitchi (QLD) - Thursday, Aug 06, 2009 at 08:24
The thought of you "doing 120 out the back of
Charleville while approaching a roadtrain" with the missus and 2 tin lids on board is enough to give me nightmares. Why such a bloody rush?
377766
Reply By: Member - Alan John C (WA) - Thursday, Aug 06, 2009 at 08:59
It is a
well known that this is a frequent occourance on Nissan patrols we had one fall off last year and the driver was told at the road house they have one a week come in and it is always left rear regards Alan.
377770
Reply By: Member - Duncs - Thursday, Aug 06, 2009 at 10:01
THis may be a frequent occurrence on Nissan Patrols but I have seen it happen on Toyota Landcruisers and Honda Accords.
I had issues with over tightened wheel nuts years ago and did a bit of investigating. It seems that there are two main causes for wheel nut or stud damage. The first is under-tightening of wheel nuts and the second is over tightening. The primary cause of both is rattle guns at tyre shops.
If you look in a workshop manual for any vehicle it will specify a torque for the wheel nuts. On a Nissan Patrol with steel
wheels, that is 80 foot pounds, a lot less than most people would imagine.
Following my research I decided to check and re-tighten my wheel nuts using a torque wrench. Now some people have said that is a bit over the top "just make sure they are good and tight!" is what is constantly thrown at me, even by my brother the mechanical engineer. It actually takes me less than 1 minute to put the torque wrench over the 6 studs on a wheel. I start at 60 ft/lb then 70 and finally 80. I have never had a problem since I started doing this.
Is that a bit obsessive? Ask what the guy with the Landcruiser 200km south of
Birdsville or the guy with the Honda at Hattah in Victoria. Having a wheel fall off at 120km/h or even 20km/h or any other speed is not fun.
A lot of people on this
forum make a big deal about manufacturers specs, the wheel nut thing is too easy to overlook and very easy to get right.
Duncs
377779
Follow Up By: Member - Allan B (QLD) - Thursday, Aug 06, 2009 at 10:36
Duncs, I agree with the torque wrench technique. The wheel studs are under considerable stress and should be set to a design torque. This can only be properly achieved by using a torque wrench or correctly calibrated pneumatic impact wrench. There seems no reluctance to use a torque wrench on other critical items such as head bolts etc. so why not wheel studs.
Also, I believe it to be appropriate to lubricate the threads and faces of the wheel nuts before applying the tightening force to ensure correct torque setting. This is normal for specification bolts in industry. The torquing action is to ensure the correct tensile force in the stud and this will not be achieved if some of the rotational force is absorbed in undefined friction. Lubrication does not cause them to more easily loosen if set to the specification torque but it does overcome corrosion action which can make intended removal difficult.
So tell me, what is the correct torque setting for my Land Cruiser Troopy with Sunrasia
wheels? Neither the owners manual or my crummy workshop manual nominate a torque figure.
645171
Follow Up By: Member - Duncs - Thursday, Aug 06, 2009 at 16:37
Allan,
If you can't find the spec elsewhere you could check with the service section of your friendly local Toyota dealer. Ask to see the figure written in the manual.
Apparently I need to check
mine again. The setting I quote was from a GQ original Nissan Manual. When I asked the Nissan dealer he said it would be the same and I took his word for it but reading below it could be wrong.
Duncs
645203
Reply By: Member - Timbo - Thursday, Aug 06, 2009 at 11:43
Michael, maybe I've missed something obvious here, but when the wheel came off, were the studs still intact or broken? In other words, what caused the wheel to come off - the nuts working loose and falling off, or the studs breaking (with the nuts still on them)?
377787
Follow Up By: Member - Ed. C. (QLD) - Thursday, Aug 06, 2009 at 12:49
Nuts coming loose will have a multiplying effect (they're only going to get looser!), which in turn will cause the studs to break, since the weight of the vehicle is now on the studs, instead of the centre boss (where it should be)...
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
645180
Reply By: Member - Ed. C. (QLD) - Thursday, Aug 06, 2009 at 12:42
Well, from what I've seen, Nissan are using the same 'acorn' nuts on their alloy
wheels as they've always used on the steel
wheels, and I reckon that this is the root of the problem...
According to folk who are more knowledgeable than I, the correct nuts for (taper
seat) alloy
wheels are the 'bulge acorn' type, as shown here
Gorilla lug nuts
The bulge nuts are said to have a 60% greater seating surface (when used with alloys) than the standard acorn nut, and are much better matched to the machined recess in the alloy wheel..
Combine under-size studs with incorrect nuts, poor seating/tightening techique, and,
well, 'taint no surprise to me that these incidents continue to occur.............
| Confucius say.....
377794
Reply By:- Thursday, Aug 06, 2009 at 16:29
Don't know if this is right, just another theory.
My mechanic showed me there is a little lip on the Patrol rear wheel hub assembly and if the wheel doesn't sit on this properly then there is the potential for the wheel to work loose and eventually come off. It is small so can be missed easily.
Just my bit.
Ev
377814
Reply By: Member - Fred - Thursday, Aug 06, 2009 at 16:30
My Nissan GU (Y61) workshop manual specifies 118-147Nm or 87-108 ftlb not the 80 ftlb as quoted above
377815
Follow Up By: Member - Duncs - Thursday, Aug 06, 2009 at 16:39
Thanks for that Fred I will check mne again. See the follow ups to my earlier post for details of why I said 80.
Duncs
645205
Reply By: Member - Ed. C. (QLD) - Thursday, Aug 06, 2009 at 19:58
The other major contributing factor that I see here is stud length/ thread engagement...
The alloy
wheels have a substantially thicker mounting pad than the steels, but the studs are the same length, resulting in a correspondingly shorter thread engagement...
All very
well nuts are torqued up correctly, and regularly checked, but as we all know, in the 'real world', this does not always happen...
That's when it all goes pear-shaped, as there is absolutely no margin for error...
Anyway, I've 'put my money where my mouth is', and replaced all of my studs w/- custom made ½" ones (cheaper than off-the -shelf Nissan ones), and they are also 6mm longer...
| Confucius say.....
377841
Follow Up By: Member - Ed. C. (QLD) - Thursday, Aug 06, 2009 at 20:01
All very
well IF THE nuts are torqued up correctly, etc. etc.....
| Confucius say.....
645223
Reply By: Member - Michael O (NSW) - Thursday, Aug 06, 2009 at 20:59
Thanks for the thoughtful replies.
By the time the wheel came off, three studs had broken, but by the rub marks on the inside of the wheel and the fact only five of the holes had been elongated, it seems the first stud broke clean off, then the rest worked loose.
I can't see any other explanation other than the stud had a hairline crack in it after the accident. The combination of torqued-up nuts at the tyre joint and a lot of km has caused it to break off. The rest must have worked loose and when the next two studs broke, the wheel came off. The hub/brake assembly landed inside the wheel thereby saving the bottom of the disc from scraping on the road (although it was damaged beyond repair anyway...)
Needed new wheel, new studs, brake disc, backing plate, and a set of wheelnuts. Thanks to the mechanic who got us back on the road today!
As for the "rush"; with the time I had, we had to get from Wagga to Charters Towers in two days, then 3 weeks to get home...
377867
Follow Up By: Member - James Bruce G (VIC) - Friday, Aug 07, 2009 at 19:05
When using
wheels in a highly loaded or outback environment it is important to follow the recommended practice of checking wheel nuts for tightness on a regular basis.
About 20 years ago I lost a wheel off a tandem horse float. Those
wheels were highly loaded when turning with two horses on board - you could see the tyres moving sideways on the rim and hear the scrubbing. After that I always checked the wheel nuts at the start of a trip and was often surprised I needed to retighten some.
A few years ago I, I fitted new steel
wheels to my Patrol. I removed and refitted them and torqued to specs (I use 100 ft-lbs, towards the upper end of the specification). Within about 400 Km I had a loose wheel and all the nuts on the other
wheels needed retightening. In that case, the problem was the paint on the new
wheels where the wheel nuts
seat. Of course that paint is not as strong as steel and squashed down requiring the nuts to be retightened.
If the nuts are too loose they will come off, if they are too tight you can break wheel studs, especially under high loads such as corrugations.
The rattle guns used by the tyre fitters are usually set too high. That means the average user won't lose a wheel due to the nuts coming off so the tyre fitter avoids blame. Only if the vehicle is used outback does the problem of fatigue and broken studs then emerge and the customer tends to blame the vehicle manufacturer, not the tyre man.
645388
