Leaf-spring specialists - Brisbane southside?
Submitted: Thursday, Aug 06, 2009 at 13:47
ThreadID: 71257 Views:5080 Replies:4 FollowUps:2
Hi all,
I'm wondering if any Brisbane people on here know of some good suspension shops that are handy with leaf springs, preferably on the south side?
I've recently bought a 79 BJ40 Landcruiser and the previous owner had fitted new springs, shocks and some longer greasable shackles. I knew the shorty cruisers tended to bounce around and l figured mine was alright. A mate recently looked it over and pointed out that my front and rear shackles were vertical, which apparently is not ideal and hence my little truck bounces around like crazy! I've been told l should replace a couple of the top leafs with slightly longer ones to get the shackles sitting right.
I've had no experience with leaves and shackles but does this sound right?
If anyone knows of some suspension gurus I'd like to hear. Or should l just go down to the nearest Pedders??
Thanks in advance,
Dan
Reply By: Moose - Thursday, Aug 06, 2009 at 13:54
Try Carrolls at Wacol.
AnswerID: 377801
Follow Up By: Falco80 - Thursday, Aug 06, 2009 at 14:05
Thanks Moose, they are 10 minutes down the road. I've never heard of them before, but i'll call in when i'm home and see what they can do for me.
Dan
FollowupID: 645188
Reply By: Member - Doug T (NT) - Thursday, Aug 06, 2009 at 14:29
Try ARB at 988 Beaudesert Road Coopers Plains for a set of OME, you won't know it's the same vehicle,
AnswerID: 377805
Reply By: toyocrusa - Thursday, Aug 06, 2009 at 16:17
Hi Dan. Just a thought. If the previous owner has fitted heavier springs then they will possibly have more leaves in them making them ride harder.If you could compare them to standard that would give you an idea. If there are extra leaves it would not be too hard to remove them. this would lower the vehicle a touch, move the shackles out and make the ride softer.You would need to make sure that the shocks compress enough to allow for the new upward movement of the spring. May be a cheaper way out of it. bob
AnswerID: 377810
Follow Up By: Falco80 - Thursday, Aug 06, 2009 at 17:33
Hi Bob, the spring packs on at the moment do not look to me like heavy duty ones. I think they were fitted just to replace the original springs and then the shackles were fitted to get a bit of lift. They have fitted castor wedges and EFS shocks at the same time, so it appears to have been done properly. The top leave in each pack just looks too short and l think with slightly longer ones it will move the shackle forward a bit and fix it. Hopefully.
Thanks for the tip though!
Dan
FollowupID: 645207
Reply By: Member - Nolo (Brisbane) - Friday, Aug 07, 2009 at 21:15
Evan at Bayside Springs on Redland bay Rd Capalaba. Very experienced at fitting after market suspension as well as re-setting springs.
AnswerID: 378081
