Stone gaurd and extension
Submitted: Thursday, Aug 06, 2009 at 19:39
mynance
Does any one have plans for a horizontal stone guard that they are willing to share. I have a Avan Cruiseliner and NT Pajero. I will be fitting a DO35 coupling from Vehicle Components so that we can open the back door of the Pajero without fouling the coupling.
I would like to extend the a frame of the cruiseliner by bolting on a 15mm plate to the a frame by 150mm are there any any legal problems with this?
Myles
Reply By: Member - Oldbaz. NSW. - Friday, Aug 07, 2009 at 10:59
Myles, I made a horizontal guard for my C/t & it was effective over roads such as Ood, Mereenie, Tanami & GRR. While I have no plans as such (or photos) it
is simple to explain. Frame of 40mm pvc pipe, screwed, not glued. Cover of
shadecloth, doubled & sewn over frame with 40 Kg Nyon fishing line. Not sure if you could adapt to suit your Avan.
Mine consists of a piece of pipe across the
A frame at the van end to the full width of trailer, 2 90 deg bends brought forward on each side, then at 45 deg to the hitch point, allowing sufficient
room to put the vehicle on full lock. Fastened by only 2 bolts through A frame
at rear & allowed to rest on top of hitch point. Holes in cloth to suit Jockey
wheel, spare wheel & whatever. It does inconvenience the access to the rear of vehicle a bit, but then again ,a broken widow is a bigger problem. Cheap as
chips, it works, & is easily removable for non dirt trips. Let me know if I can be
of any further help if you try this out.....oldbaz.
377957
Reply By: Member - Rod N (QLD) - Friday, Aug 07, 2009 at 12:46
Reply By: A J - Friday, Aug 07, 2009 at 12:49
mynace - check out thread 51796 - reply 8 of 13 - Lucy replied with attached photo which is very clear.
Lucy may still be around the
forum.
A J
377981
Reply By: time waster - Friday, Aug 07, 2009 at 18:27
